Spray Gun Recommendations, Calling all painters out there |
somd914 |
Feb 7 2016, 08:58 AM
Member Group: Members Posts: 1,171 Joined: 21-February 11 From: Southern Maryland Member No.: 12,741 Region Association: MidAtlantic Region |
I picked up a nice '73 Revenna green teener last fall that had been a stalled project. Mechanically she is back together and on the road, body is solid being a SOCAL car until the last 10 years and basically garaged for refreshing since then, but she does need paint.
I've done a bit of panel paint work, do a respectable job, and have decided to paint this car myself with the help of an experienced hobbyist painter. For this I'm looking to upgrade guns. Given the local paint shop is a Dupont retailer, I plan to use their products, will be shooting base and clear, not single stage (don't even know if I can get single stage if I wanted it...). Will also be shooting primer with this gun. Presently I have a 25 gallon compressor that is advertised to be 7.0 CFM at 90 PSI, but have no issues with upgrading my compressor now that I have a larger garage and plenty of 220 service. Any recommendations for a decent gun setup? |
worn |
Feb 7 2016, 10:04 AM
can't remember Group: Members Posts: 3,156 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
I picked up a nice '73 Revenna green teener last fall that had been a stalled project. Mechanically she is back together and on the road, body is solid being a SOCAL car until the last 10 years and basically garaged for refreshing since then, but she does need paint. I've done a bit of panel paint work, do a respectable job, and have decided to paint this car myself with the help of an experienced hobbyist painter. For this I'm looking to upgrade guns. Given the local paint shop is a Duron retailer, I plan to use their products, will be shooting base and clear, not single stage (don't even know if I can get single stage if I wanted it...). Will also be shooting primer with this gun. Presently I have a 25 gallon compressor that is advertised to be 7.0 CFM at 90 PSI, but have no issues with upgrading my compressor now that I have a larger garage and plenty of 220 service. Any recommendations for a decent gun setup? Now that I have painted 3 cars I am not sure. I have bought several guns and I use different ones for different purposes. One thing I learned on the last go around was to play with all of the adjustments to get what you want, which may not be what the manual states. I wish I had spent $400 on a gun now because I have spent $4000 in paint. Also, a mini gun is indispensable in my experience. Hopefully Rick will chime in cause he and a few others here are real experts. |
flyer86d |
Feb 7 2016, 10:28 AM
Member Group: Members Posts: 425 Joined: 12-January 11 From: Corea, Maine Member No.: 12,585 Region Association: North East States |
I have painted more than a few cars and panels and struggled with cheap guns. When I built up my 1929 Ford Roadster in 2000, I decided to spring for a good gun. I know that every one has their own preference as to type of gun so I won't get into that. I bought a Binks siphon feed gun that a child could do a good quality paint job with. A good gun is that easy to use. It was one of my best tool purchases ever!
Charlie |
somd914 |
Feb 7 2016, 10:39 AM
Thanks for the feedback worn and flyer86d.
I've done a lot of playing with my gun, AOM 5008WB, and as I mentioned I've had respectable luck with panel work, but it's a pain to find parts, and have to wonder about better results with a better gun. Also I've found differences in materials, i.e. inexpensive paints typically don't spray well, at least for me. |
jmill |
Feb 7 2016, 12:06 PM
Painted lots of cars with a cheap siphon feed gun. Lots of overspray and orange peel. Bought this and never looked back.
Attached thumbnail(s) |
914GT |
Feb 7 2016, 06:59 PM
Senior Member Group: Members Posts: 1,100 Joined: 11-October 04 From: Tucson Member No.: 2,923 Region Association: Southwest Region |
I've been using a Tekna Copper gun the past few years and it has been very good.
Guy |
Andyrew |
Feb 7 2016, 07:11 PM
I used a Husky hvlp gun, I have a nice gun now but in reality you can find a gun that will give you 99% of a $500 gun for under 100.
I buy all my consumables and paint from www.tcpglobal.com and they have a great selection of guns as well. Read the first half of my build thread for tips on paint and body. |
Wdunster |
Feb 7 2016, 10:40 PM
Panel beater Group: Members Posts: 172 Joined: 10-June 14 From: Monroe,nc Member No.: 17,469 Region Association: South East States |
Okay. Hold on a sec. Did you say Duron? That is house paint. I am a painter by trade with 32 years in the business and currently work for PPG automotive coatings. I would recommend base clear for every job! Because you can work with the color until you get it how you like it then lock it in with clear. Even if you use a single stage urethane I would integrate clear in the last coat for durability. As far as paint guns I would recommend a good quality HVLP if you have the compressor to handle the air volume. HVLP uses a lot of air at low pressure. I would also recommend using a gun with a 1.4 or 1.3 fluid tip. The "cheap" guns you can get typically have too big of a tip and will make for a less than stellar job. Like spraying with a garden hose. Any of the paint gun manufacturers guns will be a good choice. Data, Devilbiss, Iwata. They are more expensive but the results are very noticeably better.
I feel sure there is a good automotive paint supplier in your area that would be happy to assist. Also look on PPG automotive coatings website for tips and tutorials. Ppg A automotive also had great videos on you tube. Good luck and let me know if I can help. Bill |
somd914 |
Feb 8 2016, 04:43 AM
Okay. Hold on a sec. Did you say Duron? That is house paint. I am a painter by trade with 32 years in the business and currently work for PPG automotive coatings. I would recommend base clear for every job! Because you can work with the color until you get it how you like it then lock it in with clear. Even if you use a single stage urethane I would integrate clear in the last coat for durability. As far as paint guns I would recommend a good quality HVLP if you have the compressor to handle the air volume. HVLP uses a lot of air at low pressure. I would also recommend using a gun with a 1.4 or 1.3 fluid tip. The "cheap" guns you can get typically have too big of a tip and will make for a less than stellar job. Like spraying with a garden hose. Any of the paint gun manufacturers guns will be a good choice. Data, Devilbiss, Iwata. They are more expensive but the results are very noticeably better. I feel sure there is a good automotive paint supplier in your area that would be happy to assist. Also look on PPG automotive coatings website for tips and tutorials. Ppg A automotive also had great videos on you tube. Good luck and let me know if I can help. Bill Oops, too much house painting going on with this "new" old house... (IMG:style_emoticons/default/headbang.gif) Make that DuPont... And they are 40 miles away - kind of live in the sticks. They appear to be more of just a retailer than knowledgeable car painters, but that seems to be retail in general. And being a DuPont retailer they also sell Nason, but for me with my AOM HLVP gun (with 1.2 and 1.4 tips), I've had better results with DuPont Chromabase products. Thanks for all the feedback to everyone. More to consider and more research. |
Wdunster |
Feb 8 2016, 06:30 AM
Okay. Hold on a sec. Did you say Duron? That is house paint. I am a painter by trade with 32 years in the business and currently work for PPG automotive coatings. I would recommend base clear for every job! Because you can work with the color until you get it how you like it then lock it in with clear. Even if you use a single stage urethane I would integrate clear in the last coat for durability. As far as paint guns I would recommend a good quality HVLP if you have the compressor to handle the air volume. HVLP uses a lot of air at low pressure. I would also recommend using a gun with a 1.4 or 1.3 fluid tip. The "cheap" guns you can get typically have too big of a tip and will make for a less than stellar job. Like spraying with a garden hose. Any of the paint gun manufacturers guns will be a good choice. Data, Devilbiss, Iwata. They are more expensive but the results are very noticeably better. I feel sure there is a good automotive paint supplier in your area that would be happy to assist. Also look on PPG automotive coatings website for tips and tutorials. Ppg A automotive also had great videos on you tube. Good luck and let me know if I can help. Bill Oops, too much house painting going on with this "new" old house... (IMG:style_emoticons/default/headbang.gif) Make that DuPont... And they are 40 miles away - kind of live in the sticks. They appear to be more of just a retailer than knowledgeable car painters, but that seems to be retail in general. And being a DuPont retailer they also sell Nason, but for me with my AOM HLVP gun (with 1.2 and 1.4 tips), I've had better results with DuPont Chromabase products. Thanks for all the feedback to everyone. More to consider and more research. No worries. Axalta (formerly DuPont) will work. Take the label off its just chemistry. Good luck B |
Andyrew |
Feb 8 2016, 07:17 AM
I had extremely bad luck with Nason painting Peters(malaga_red75 car). Read my paint thread for him on it in my sig. I wont use that product again.
Catorse |
Feb 8 2016, 09:51 AM
Member Group: Members Posts: 194 Joined: 27-August 15 From: Los Angeles Member No.: 19,106 Region Association: Southwest Region |
Best gun out there for the money - Iwata LPH400. You'll pay about $400, but it is an awesome gun used by pros. Bonus when shooting PPG is that PPG gives you gun setup paramters FOR THAT ACTUAL GUN, because it is a pro gun.
I ran it with an 80 gallon compressor. No issues, painted the whole car beautifully. Attached image(s) |
Wdunster |
Feb 8 2016, 10:29 AM
Best gun out there for the money - Iwata LPH400. You'll pay about $400, but it is an awesome gun used by pros. Bonus when shooting PPG is that PPG gives you gun setup paramters FOR THAT ACTUAL GUN, because it is a pro gun. I ran it with an 80 gallon compressor. No issues, painted the whole car beautifully. Iwata is my gun of choice too. Looks awesome. What did you put on it? |
Andyrew |
Feb 8 2016, 10:45 AM
Best gun out there for the money - Iwata LPH400. You'll pay about $400, but it is an awesome gun used by pros. Bonus when shooting PPG is that PPG gives you gun setup paramters FOR THAT ACTUAL GUN, because it is a pro gun. I ran it with an 80 gallon compressor. No issues, painted the whole car beautifully. Same gun I have. (IMG:style_emoticons/default/smile.gif) Very good gun, Sprayed my dads El Camino and Peters car with it. A beginner will NOT notice the difference between it and a $100 gun, (I still have my Husky gun for quick jobs, good gun). |
worn |
Feb 8 2016, 10:47 AM
currently work for PPG automotive coatings. I would recommend base clear for every job! Because you can work with the color until you get it how you like it then lock it in with clear. Even if you use a single stage urethane I would integrate clear in the last coat for durability. Bill I like the PPG products. Also I think the idea of a base clear is a good one. I used single stage for my old cars out of a sense of period, but it seems a lot easier when I fix a ding on my wife's modern car with base clear. Yes, I was driving the mini van when the ding occurred, but it was at least in the Harbor Freight parking lot. |
Andyrew |
Feb 8 2016, 10:51 AM
currently work for PPG automotive coatings. I would recommend base clear for every job! Because you can work with the color until you get it how you like it then lock it in with clear. Even if you use a single stage urethane I would integrate clear in the last coat for durability. Bill I like the PPG products. Also I think the idea of a base clear is a good one. I used single stage for my old cars out of a sense of period, but it seems a lot easier when I fix a ding on my wife's modern car with base clear. Yes, I was driving the mini van when the ding occurred, but it was at least in the Harbor Freight parking lot. I dont know about that.. Mix a couple drops of Color and an appropriate couple drops of hardner in a plastic cup, clean the chip with wax and grease remover, then get a couple of toothpicks and grab a drop and drop it into the chip. Wait a month (or 3 years in my case...) and wetsand it flat and polish by hand. |
Kraftwerk |
Feb 8 2016, 11:02 AM
Member Group: Members Posts: 195 Joined: 6-September 07 From: Bbbbbrroooklynnn Member No.: 8,085 |
Saw a documentary of the Lamborghini factory painters, actually they ship the bodies 75 km away, since the factory doesn't have in-house painting facilities (!) There are two guys who shoot the panels simultaneously one guy does the inside the other guy does the outside in the opposite direction. Auto painting fascinates me, seems like there is magic involved.
Catorse |
Feb 8 2016, 01:07 PM
Best gun out there for the money - Iwata LPH400. You'll pay about $400, but it is an awesome gun used by pros. Bonus when shooting PPG is that PPG gives you gun setup paramters FOR THAT ACTUAL GUN, because it is a pro gun. I ran it with an 80 gallon compressor. No issues, painted the whole car beautifully. Iwata is my gun of choice too. Looks awesome. What did you put on it? PPG Envirobase, PPG Clear, color is AUBERGINE. |
Wdunster |
Feb 8 2016, 01:50 PM
Best gun out there for the money - Iwata LPH400. You'll pay about $400, but it is an awesome gun used by pros. Bonus when shooting PPG is that PPG gives you gun setup paramters FOR THAT ACTUAL GUN, because it is a pro gun. I ran it with an 80 gallon compressor. No issues, painted the whole car beautifully. Iwata is my gun of choice too. Looks awesome. What did you put on it? PPG Envirobase, PPG Clear, color is AUBERGINE. Like it!!!! (IMG:style_emoticons/default/beerchug.gif) |
Catorse |
Feb 8 2016, 03:17 PM
Best gun out there for the money - Iwata LPH400. You'll pay about $400, but it is an awesome gun used by pros. Bonus when shooting PPG is that PPG gives you gun setup paramters FOR THAT ACTUAL GUN, because it is a pro gun. I ran it with an 80 gallon compressor. No issues, painted the whole car beautifully. Iwata is my gun of choice too. Looks awesome. What did you put on it? PPG Envirobase, PPG Clear, color is AUBERGINE. Like it!!!! (IMG:style_emoticons/default/beerchug.gif) Thanks bro, I know you work for PPG, but honestly, with this build I did not want to screw around. I wanted the BEST. For me, that means PPG. Total cost of paint was $1400 with everything, hardeners, base, clear, strainers, One Choice cleaner, etc etc. Worth every penny. This product is OUTSTANDING. |
Lo-Fi Version | Time is now: 19th May 2024 - 10:00 PM |
