New intake system, Made by Mario at the dub shop |
Henshe |
Feb 7 2016, 12:32 PM
Newbie Group: Members Posts: 15 Joined: 9-April 14 From: Burlington, Wa Member No.: 17,232 Region Association: Pacific Northwest |
Mario, of the dub shop (thedubshop.net) fabed up an awesome intake for the 914. It looks great and now I can even hear the Tangerine Racing exhaust over the itb's. (IMG:style_emoticons/default/piratenanner.gif) |
Elliot Cannon |
Feb 8 2016, 12:21 PM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
Nice, clean installation but seems to be a solution in search of a problem. IMHO. Normally, I would not disagree with Mark, however don't throw away the cross bar linkage. It can be modified easily. There was a thread on how to do this some years ago but I can't find it. I did mine and there is absolutely NO play in the linkage. Here's mine.
Attached image(s) |
Mark Henry |
Feb 8 2016, 02:41 PM
Nice, clean installation but seems to be a solution in search of a problem. IMHO. Normally, I would not disagree with Mark, however don't throw away the cross bar linkage. It can be modified easily. There was a thread on how to do this some years ago but I can't find it. I did mine and there is absolutely NO play in the linkage. Here's mine. Hate to tell you this, but I don't like your linkage. For one in this pic the angle of the connecting arm puts a large thrust (side) load on the carb, it will cause premature wear. A crossbar linkage can be done, but I rarely see one I feel is acceptable. Except for the Gene Berg for a type 1, I've never seen a good crossbar set-up out of the box. (IMG:http://www.914world.com/bbs2/uploads/post-7407-1454955688.jpg) |
r_towle |
Feb 8 2016, 05:02 PM
Custom Member Group: Members Posts: 24,577 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Nice, clean installation but seems to be a solution in search of a problem. IMHO. Normally, I would not disagree with Mark, however don't throw away the cross bar linkage. It can be modified easily. There was a thread on how to do this some years ago but I can't find it. I did mine and there is absolutely NO play in the linkage. Here's mine. Hate to tell you this, but I don't like your linkage. For one in this pic the angle of the connecting arm puts a large thrust (side) load on the carb, it will cause premature wear. A crossbar linkage can be done, but I rarely see one I feel is acceptable. Except for the Gene Berg for a type 1, I've never seen a good crossbar set-up out of the box. (IMG:http://www.914world.com/bbs2/uploads/post-7407-1454955688.jpg) Yah, I don't like your linkage either.....not that I have personally seen your linkage. Also, why is it all red in there? Did you run out of black pain? The big issue I had with any cross bar linkage is the engine expands when it gets hot. I measured mine and it was not trivial. That expansion is not accounted for in a cross bar linkage, th cross bar just gets loose. I ended up with Foleys cable system and it really is a one shot deal, set it and forget it. |
Lo-Fi Version | Time is now: 21st May 2024 - 06:13 PM |
