New intake system, Made by Mario at the dub shop |
Henshe |
Feb 7 2016, 12:32 PM
Newbie Group: Members Posts: 15 Joined: 9-April 14 From: Burlington, Wa Member No.: 17,232 Region Association: Pacific Northwest |
Mario, of the dub shop (thedubshop.net) fabed up an awesome intake for the 914. It looks great and now I can even hear the Tangerine Racing exhaust over the itb's. (IMG:style_emoticons/default/piratenanner.gif) |
Darren C |
Feb 9 2016, 08:17 AM
Member Group: Members Posts: 392 Joined: 26-December 14 From: Chichester UK Member No.: 18,255 Region Association: England |
Interesting centre linkage you have there Edwin.
If the crank arms are at 45 degrees like standard twin carbs, you have your centre twin arm crank set up incorrectly. (IMG:http://www.914world.com/bbs2/uploads_offsite/i265.photobucket.com-18255-1455027470.1.jpg) I see this quite a lot, even with the dreadful cross bar linkages. Throttle cable movement when transmitted through a crank unless set right will give you an exponential throttle opening. Hopefully my sketch shows what I mean. since the main crank point (where the throttle arms attach, scribe an arc; once they pass over the crest of any arc lateral movement is compromised by side movement, giving a disproportionate throttle opening in comparison to gas pedal depression). Perfect proportional throttle is achieved if the centre main pivot has arms the same length as the carbs or throttle bodies; and the throttle cable bell crank arm length is calculated at a 90 degree rotational pull arc, based on linear cable pull. |
ChrisFoley |
Feb 9 2016, 10:33 AM
I am Tangerine Racing Group: Members Posts: 7,927 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
... Throttle cable movement when transmitted through a crank unless set right will give you an exponential throttle opening. ... A cable wrapped around a pulley has linear throttle response. Just sayin' (IMG:style_emoticons/default/biggrin.gif) |
Darren C |
Feb 9 2016, 11:00 AM
... Throttle cable movement when transmitted through a crank unless set right will give you an exponential throttle opening. ... A cable wrapped around a pulley has linear throttle response. Just sayin' (IMG:style_emoticons/default/biggrin.gif) I never mentioned a pulley, you're correct but in an unrelated way to the original meaning, as Cooper says and my observation of Edwin's photograph. |
Lo-Fi Version | Time is now: 21st May 2024 - 06:23 AM |
