STEAM CLEANING, good referal |
rhodyguy |
Jun 14 2003, 07:27 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,080 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
for locals this is the deal. off of the portland ave exit of hwy 512 there is a firm that does steam cleaning. this is not someone with a generic presure washer. your car goes up on a lift and the guy has this desel fired steam cleaner. not a slap dash operation. he seems slow but that's the up side, he works til it's clean. i had the jetta done, $50. when the 73's up and going it will be next. i highly recommend this guy. I BELIEVE HE'S OPEN 6 DAYS A WEEK!
AIRPORT ROAD STEAM CLEANING AND UNDERCOATING 2103 E 112th st tacoma 253-537-6561 kevin |
rhodyguy |
Jun 14 2003, 09:43 AM
one thing to note. while steam is just heated water, you avoid the problems with the forced water being injected into every nook and crany, even @ 21psi. if you think that's gentle, stick your hand right infront of the wand. the steam vapor softens the junk as opposed to cutting it. the epa is very strict with regards to disposal, seperators and all. hosing the crap down to a storm drain from your driveway is irresponsible. castrol super clean, grease, grime, into surface runoff water should be punnished with jail time and a big fine. i'm not a tree hugger either.
kevin |
Lo-Fi Version | Time is now: 18th May 2024 - 09:38 AM |
