help - i screwed up on my v8 - advice needed |
jimkelly |
Feb 9 2016, 01:31 PM
last week we determined that some of my oil leak problem was 4 bolts holding my carb intake to the heads, so we applied sealant and 3 stopped leaking. on Saturday I thought i'd address the last one that did not stop leaking, so not only did I add sealant to it again, I decided to use a longer bolt because the other 3 were longer. I used a 1.5" bolt but it turns out the other were probably 1.25", the max that should be used. so anyway, monday go for a drive but power is weird, I figured it had to do with engine being cold and I just changed the fuel filter and thought maybe there was some starving going on, but 30 minutes later I decided to go back home and figure out what was wrong. anyway, yesterday I pull the valve cover off to find a cracked valve rod that I retrieved from the head with a magnet on a stick but I had to remove the intake to put the lifter back in the head. anyway, it is all back together but it revs ok in neutral but under load it is either valves or knocking. what you think? anyway, why does a guy with so little mechanical prowess own a 914, who the hell knows. i'd like to think the noise is due mostly to timing cause I of course had to pull the distributor. and I never put a tdc mark on my flywheel or crank balancer, need to, asap. I first thought it was vacuum advance problem but vacuum is pulling thru hose.
https://www.youtube.com/watch?v=tfKEa1-W0XQ video is being loaded, pls check back and comment. pls pls. Attached thumbnail(s) Attached image(s) |
bretth |
Feb 10 2016, 04:39 PM
Senior Member Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region |
As others have said, disable ignition and fuel pump. Then keep the throttle wide open while cranking. You need to crank motor about 4 times and see the psi then. Also notice roughly how high the compression climbs on each crank compared to other cylinders. I would also remove all of the spark plugs during testing for most accurate reading. Good luck.
Brett |
Lo-Fi Version | Time is now: 17th May 2024 - 12:32 AM |
