help - i screwed up on my v8 - advice needed |
jimkelly |
Feb 9 2016, 01:31 PM
last week we determined that some of my oil leak problem was 4 bolts holding my carb intake to the heads, so we applied sealant and 3 stopped leaking. on Saturday I thought i'd address the last one that did not stop leaking, so not only did I add sealant to it again, I decided to use a longer bolt because the other 3 were longer. I used a 1.5" bolt but it turns out the other were probably 1.25", the max that should be used. so anyway, monday go for a drive but power is weird, I figured it had to do with engine being cold and I just changed the fuel filter and thought maybe there was some starving going on, but 30 minutes later I decided to go back home and figure out what was wrong. anyway, yesterday I pull the valve cover off to find a cracked valve rod that I retrieved from the head with a magnet on a stick but I had to remove the intake to put the lifter back in the head. anyway, it is all back together but it revs ok in neutral but under load it is either valves or knocking. what you think? anyway, why does a guy with so little mechanical prowess own a 914, who the hell knows. i'd like to think the noise is due mostly to timing cause I of course had to pull the distributor. and I never put a tdc mark on my flywheel or crank balancer, need to, asap. I first thought it was vacuum advance problem but vacuum is pulling thru hose.
https://www.youtube.com/watch?v=tfKEa1-W0XQ video is being loaded, pls check back and comment. pls pls. Attached thumbnail(s) Attached image(s) |
jimkelly |
Feb 12 2016, 05:28 PM
when people say a sbc can be reved to 6500 or some other number, do they mean it can be run for 15-30 mins at that rpm or do they mean that it can be screamed to that number and then promptly shifted??
mgp4591 |
Feb 12 2016, 05:54 PM
914 Guru Group: Members Posts: 5,374 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
when people say a sbc can be reved to 6500 or some other number, do they mean it can be run for 15-30 mins at that rpm or do they mean that it can be screamed to that number and then promptly shifted?? Depends on how you build it. Get a Traco engine and it'll run all day at 7grand. Another friend had a 25k Rehrer-Morrison smallblock that'd rev to 14g but not for too long. Big bucks go a long way in building a revvy Chev engine but you probably don't need that. I've seen some impressive numbers and rev ability from the 4.3 v-6 too - look some of them up and see if it's what you want. They even sound kinda cool! (IMG:style_emoticons/default/shades.gif) |
Lo-Fi Version | Time is now: 16th May 2024 - 11:05 PM |
