Stock rebuild or go 2056 with D-Jet, At a crossroads |
saigon71 |
Feb 10 2016, 12:41 PM
Senior Member Group: Members Posts: 1,998 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
I'm rebuilding my engine this winter. My original plan was to stay pretty much stock (including pistons & cylinders). My cam shows signs of wear on the lobes, so it needs to be replaced, along with new lifters. Piston rings are shot but P & C's are in spec. Heads will be rebuilt & all new bearings installed.
I'm sticking with D-jet and ordered a new wiring harness from Bowlsby. What I really love about my current setup with the stock 2.0 D-jet is the drivability and the overall lack of tinkering required to keep it going. I don't need a fire-breathing type 4 and don't want to mess around with external oil coolers & other add-ons because of heat concerns. This is a case of "while your in there." With the engine already torn down and for slightly more $$$ I'm considering building a 2056 with a slightly more aggressive (d-jet compatible) cam. My question is, what additional work is required to make D-jet work on a 2056 with a more aggressive cam. Is it just tweaking the MPS? Do I need to buy or install an air fuel meter? To someone who's been down this road, is it worth it? Thanks! |
Tom_T |
Feb 10 2016, 01:05 PM
TMI.... Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
Bob -
Another choice wouldd be to go with the 8.0:1 Euro P&Cs & D-jet - IIRC the same Cam, so replace to a stock cam. Porsche stated they were 100 HP in Euro vs. 95 HP USA, but both of those numbers were conservative in reality, plus you can tweak it up a bit more with some MPS tweaks & a few other tricks. Rich Bontemi at HPH in Redwood City & some of the other old school stock /4 racers can explain it better than I. Rich also recco's lightening the flywheel for faster response. I know folks with both Euro 2L P&Cs & 2056 with D-jet who are satisfied. McMark knows the 2056 inside & out, so PM him at Original Customs for that side.. Good Luck! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
Lo-Fi Version | Time is now: 14th May 2024 - 10:25 AM |
