Stock rebuild or go 2056 with D-Jet, At a crossroads |
saigon71 |
Feb 10 2016, 12:41 PM
Senior Member Group: Members Posts: 1,998 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
I'm rebuilding my engine this winter. My original plan was to stay pretty much stock (including pistons & cylinders). My cam shows signs of wear on the lobes, so it needs to be replaced, along with new lifters. Piston rings are shot but P & C's are in spec. Heads will be rebuilt & all new bearings installed.
I'm sticking with D-jet and ordered a new wiring harness from Bowlsby. What I really love about my current setup with the stock 2.0 D-jet is the drivability and the overall lack of tinkering required to keep it going. I don't need a fire-breathing type 4 and don't want to mess around with external oil coolers & other add-ons because of heat concerns. This is a case of "while your in there." With the engine already torn down and for slightly more $$$ I'm considering building a 2056 with a slightly more aggressive (d-jet compatible) cam. My question is, what additional work is required to make D-jet work on a 2056 with a more aggressive cam. Is it just tweaking the MPS? Do I need to buy or install an air fuel meter? To someone who's been down this road, is it worth it? Thanks! |
914dave |
Feb 11 2016, 05:18 AM
914 Addict Group: Members Posts: 700 Joined: 19-October 03 From: Willow Grove Pa. Member No.: 1,262 Region Association: North East States |
Bob
I ran a 2056 with Web's injection cam (mild upgrade) and the 2056 with the stock injection. It ran well and acted civilized in normal traffic. The guy I sold it to is still running it. Watch out for the "while I'm in there", that can lead down a long dark road! hehe Dave |
JOEPROPER |
Feb 11 2016, 08:13 AM
The answer is "no" unless you ask... Group: Members Posts: 1,184 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States |
Bob I ran a 2056 with Web's injection cam (mild upgrade) and the 2056 with the stock injection. It ran well and acted civilized in normal traffic. The guy I sold it to is still running it. Watch out for the "while I'm in there", that can lead down a long dark road! hehe Dave Bob, did you stick with the stock 7.6:1 CR? Wondering if a slight bump to 8.0:1 (like Euro models) or even 8.5:1 would have any negative effect. Are the Euro D-Jet systems the same? (injectors, pulse width etc...)? |
Lo-Fi Version | Time is now: 14th May 2024 - 04:04 AM |
