Stoping the Evil Iron-Oxide...., Some Products... Any Comments??? |
dagdal1967 |
Jun 14 2003, 09:48 AM
What are YOU looking at... Group: Members Posts: 372 Joined: 13-March 03 From: Carrollton, Texas Member No.: 423 |
Hey all..
Although I have a VERY clean car, it still has a couple little areas of surface rust that I want to stop before they become a problem. I've been researching ways of doing this without going for a bare metal grind and re-spray, and came across the following.... The Rust Doctor is a liquid that you actually paint on the rusted surface, and it converts the rust to an inert form of Iron-oxide called magnetite (??) THIS ONE EVEN HAS A PORSCHE 914 RESTORATION AS A REFERENCE!!!!!! POR-15 is similar but seems to work slightly differently. Has anyone had any experience with these, and if so what is your opinion? Just wondering before I go overboard with something that is complete crap.. Thanks guys.. Later Dougie |
tod914 |
Jun 15 2003, 08:58 AM
Advanced Member Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
rustmort is a good product. you will have to epoxy prime and paint over it - por15 i wasnt fond of although alot of people like it. por15 is a 1 step deal, its not necessary to paint over it. ive also used rustoleum - seemed to work fine - thats is more of a primer type paint. wire brush off as much of the rust as u can before applying any of these. im going the rustmort way and then expoxy primer and paint for the small areas i need to address. im sure some of the body shop guys could advise you much better than i can.
Dave Cawdrey |
Jun 15 2003, 09:28 AM
Dumbo going poop, Daddy :) Group: Members Posts: 818 Joined: 22-January 03 From: Seattle, WA USA Member No.: 182 |
QUOTE(tod914 @ Jun 15 2003, 06:58 AM) por15 is a 1 stepdeal POR 15 is actually a 3 step process. It works really well, if you follow the directions. QUOTE its not necessary to paint over it. And a top coat is needed if the POR 15 is in direct sunlight... POR gets my vote (IMG:style_emoticons/default/smilie_pokal.gif) Attached image(s) |
tat2dphreak |
Jun 15 2003, 09:33 AM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
por-15 is the shizznit... the best I've seen!
but if you want a cheap product for a simple job (something that doesn't get wet) you can use KILZ as a rust stopping/preventive.. it's a 1 step.. |
Lo-Fi Version | Time is now: 6th May 2024 - 04:16 AM |
