Hot Start Relay, What Rating? |
andys |
Feb 10 2016, 07:49 PM
Advanced Member Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None |
When I originally built my LS1 conversion car, I didn't add a relay for the starter solenoid (to save the ignition switch). I can retrofit one quite easily, however what rating of relay is really necessary? I have a 30 amp, which would seem to me to be plenty good to activate the solenoid. Thoughts?
Andys |
57lincolnman |
Feb 10 2016, 08:19 PM
Member Group: Members Posts: 174 Joined: 14-September 10 From: Los Angeles Member No.: 12,175 Region Association: Southern California |
I have a 15 amp fuse on mine. I wouldn't go higher than that. Make sure your starter and solenoid are in good working order. If the solenoid hangs up it'll blow the fuse when that happens. I put the fuse mounted on the firewall. If it does blow I don't have to crawl underneath a hot engine and heat exchanger to change it.
Lo-Fi Version | Time is now: 20th May 2024 - 11:08 PM |
