Hot Start Relay, What Rating? |
andys |
Feb 10 2016, 07:49 PM
Advanced Member Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None |
When I originally built my LS1 conversion car, I didn't add a relay for the starter solenoid (to save the ignition switch). I can retrofit one quite easily, however what rating of relay is really necessary? I have a 30 amp, which would seem to me to be plenty good to activate the solenoid. Thoughts?
Andys |
iankarr |
Feb 10 2016, 11:46 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,473 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
All my starter troubles ended when I did the Ford relay "upgrade". This thread was helpful. Especially the wiring diagram... http://www.914world.com/bbs2/index.php?showtopic=259055 |
GregAmy |
Feb 11 2016, 07:37 AM
Advanced Member Group: Members Posts: 2,302 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
All my starter troubles ended when I did the Ford relay "upgrade". Ditto, except I used the Pelican kit with the Bosch relay. I know a lot of folks like to try to get to the bottom of the issue, but in my mind the root cause is a poor electrical design. Let this relay handle the amps for the solenoid, and use that crappy wire and ignition switch to just activate the relay. Another option: http://www.amazon.com/gp/product/B001COAX78 BTW, if you go with the above or Pelican's (I think it's the same thing) put that fuse holder somewhere you can easily get to it. I popped mine one night this past year and could not change it because I was in nice clothes. It's now mounted in the engine compartment. |
Lo-Fi Version | Time is now: 17th May 2024 - 01:24 PM |
