Hot Start Relay, What Rating? |
andys |
Feb 10 2016, 07:49 PM
Advanced Member Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None |
When I originally built my LS1 conversion car, I didn't add a relay for the starter solenoid (to save the ignition switch). I can retrofit one quite easily, however what rating of relay is really necessary? I have a 30 amp, which would seem to me to be plenty good to activate the solenoid. Thoughts?
Andys |
andys |
Feb 11 2016, 03:56 PM
Thanks for the replies!
I hadn't considered a fuse, so yes I'll add one (I have an open slot in my power distribution fuse block). I would think a 10 or 15 amp fuse would be good enough. Andys |
Mark Henry |
Feb 11 2016, 04:32 PM
andys |
Feb 11 2016, 05:01 PM
Thanks for the replies! I hadn't considered a fuse, so yes I'll add one (I have an open slot in my power distribution fuse block). I would think a 10 or 15 amp fuse would be good enough. Andys Why do you need a fuse? To gain two more potential fail points? Here's my setup: I have an 6 position distribution fuse block (two rad. fans, fuel pump, OBD2) with two open slots, fed by an 8ga wire that's protected by a 50 amp circuit breaker. I think it's a good idea to protect the solenoid wire with a fuse to avoid drawing up to 50 amps should a short or overload occur. The the fuse block will be my power source for the relay/solenoid wire. Andys |
Mark Henry |
Feb 11 2016, 08:46 PM
Thanks for the replies! I hadn't considered a fuse, so yes I'll add one (I have an open slot in my power distribution fuse block). I would think a 10 or 15 amp fuse would be good enough. Andys Why do you need a fuse? To gain two more potential fail points? Here's my setup: I have an 6 position distribution fuse block (two rad. fans, fuel pump, OBD2) with two open slots, fed by an 8ga wire that's protected by a 50 amp circuit breaker. I think it's a good idea to protect the solenoid wire with a fuse to avoid drawing up to 50 amps should a short or overload occur. The the fuse block will be my power source for the relay/solenoid wire. Andys OK....I just take power from the large battery cable + on the solenoid. This pic from several years ago and I do a better a crimp job* but it shows the wiring well. Like I said, not a single OE wire is cut or any holes drilled. (IMG:http://www.914world.com/bbs2/uploads/post-26-1279679188_thumb.jpg) This shows how I bolt it to the lower starter bolt. Be careful bending the bracket so you don't stress the solenoid housing and note that the solenoid does ground on the bracket (IMG:http://www.914world.com/bbs2/uploads/post-26-1279679515_thumb.jpg) *I know the crimps are messy this wiring was either one of my first attempts from the 80's or someone else's work. I do remember grabbed quickly at the time just to show how I wire and mount the solenoid. I remove the yellow plastic, crimp it correctly and shrink tube the ends, Plus on the ford small post I use a ring spade adapter like below when I do it. BTW that is the 901 (911) with 914 gearing that is in my '67 VW bug, in case you are wondering. (IMG:http://www.914world.com/bbs2/uploads_offsite/www.polevolt.co.uk-26-1455245159.1.jpg) |
Lo-Fi Version | Time is now: 20th May 2024 - 05:06 PM |
