> I need an old time porsche mechanic for my 924 woes, Got another NARP
garrettlee2
post Feb 10 2016, 08:50 PM
Well I trade a bathroom remodel for a 1977 martini 924. The car is beautiful original paint 2 owner car. The problem I'm having is the fuel pump doesn't always work when the key is on. We hit it with portapower and it works great, so the pump isn't the problem. I was thinking relay NLA but my local porsche guy says it's not the relay. He said he would tell me how to fix it for $100. So before I blow good money on his opinion I figured someone he might know. So please help me solve this one. I need Captain Krusty!
Mark Henry
post Feb 10 2016, 09:24 PM
that's what I do!
http://en.lmgtfy.com/?q=924+fuel+pump+relay+issue+1977
Fuel pump issues: Why does my car have two fuel pumps? Is my fuel pump bad?
One symptom of a bad pump, broken hose, and/or clogged screen is engine misses at high power under severe cornering at progressively higher fuel quantities. A good system will run on a track all the way to 'empty' without problem. If the problem is not tied to cornering or gas level, there’s a possibility of simply a clogged fuel filter. The fuel filter is located in the engine compartment near the air filter; the pump is bolted to the rear fender behind the right rear wheel. Later cars have an additional fuel pump inside the tank.
This was part of the continuous improvement to correct fuel supply inadequacies. The in-tank pump is low pressure and simply provides a pressure 'head' to the high pressure pump. This is common practice, for example, in aircraft turbine engines that use high pressure (HP) pumps which rely on the fuel for lubrication of the HP pump. Exactly the case in the 924.
Before replacing the fuel pump, however, consider replacing the fuel pump relay and fuse. These are much less expensive, and are also subject to deterioration too. Just check to make sure you can feel the relay “click” as it closes the contacts when the engine is switched to start. You can also use a voltmeter at the fuel pump contacts to check for power back there – a break in the wiring is possible, though unlikely.
Anyone with in-tank pumps should take the time to pull the unit for inspection. The pump is connected to the fitting by a short section of 'hose'. After all these years you may find the hose is cracked from vibration. If so the system is essentially gravity feed to the HP pump intake. A separated hose leaves the pump connected to the tank fitting by only the 2 electrical wires, so remove the unit carefully.
On the inlet side of the submerged pump is a fine mesh screen. It also, has been in there for some 20 years and WILL be at least partially clogged. 'Slosh' it in clean fuel and use a SOFT toothbrush to dislodge the crud. You do not want to force crud into the screen where it will eventually make its way to the expensive main HP pump.
With the pump assembly DRY of GASOLINE!! Hook it up to a 12 volt battery. Use wires long enough that any spark will be removed from the pump! If it spins (makes noise is the technical term) then it works. For more detailed testing of the fuel pump, to check on how well the pump is performing or how likely it is do fail, see the Technical Section about the Fuel Delivery System.
What kills the pump(s) is bad quality gas, crud in the gas tank, or repeatedly running the tank dry/nearly dry. These pumps rely on the gas to cool the motor, so they can quickly overheat and seize if run dry. The pump element is a roller pump design. The original Bosch pumps used and still use metal roller elements. Consult the Haynes manual for a diagram of what this looks like. What it means to you is that there are very close tolerances in the pump element that do not tolerate dirt. If they get dirty, they will jam. Similarly, if they sit with watery fuel, the water will corrode the pump elements and cause them to stick. Pierburg, a subsidiary of Hella, makes a better pump - they have plastic roller elements which can tolerate the dirt, and won't corrode in water. This also supports the recommendation that you drive your car regularly! If you keep passing fuel through the system, water in your fuel will not have time to settle and cause corrosion, and dirt build-up will be kept to a minimum. See the Technical Section on Fuel Pumps for more info and part numbers.
If you have an early '77 924, and are shocked by the cost of the replacement fuel pump!!! Read the Technical Section on Fuel Pumps for information about how to update to a later-style pump for a fraction of the cost of the old style.
http://www.924board.org/viewtopic.php?t=36...c79c2b2dd8cdf52
http://www.924.org/techsection/GarageFAQ.htm
jmill
post Feb 10 2016, 09:27 PM
Green Hornet
Go to 924.org. I was a member there when I had my 924S. It was a great group of guys like this forum.
shoguneagle
post Feb 10 2016, 11:03 PM
shoguneagle
Follow all the information given above. Also, consider what type of fuel system, carbs, L-Jetronics, etc. Some types require the battery to be charged and hold above 10+ volts when starting (safety feature), some have check valves that hold the pressure when not running, etc.
The main thing is that you can do it by inquiring, understanding, ask questions, and all the above information that has been given. One of the fun things in owning any sports car as a 924 is working on it and driving it. All part of the hobby.
- Lo-Fi Version Time is now: 6th March 2026 - 07:21 PM
