Another productive weekend |
watsonrx13 |
Mar 20 2005, 04:53 PM
Advanced Member Group: Members Posts: 2,734 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
Well, this weekend I repaired the A/C holes.
Here's the before behind the rocker panel. Attached image(s) |
watsonrx13 |
Mar 20 2005, 04:54 PM
Here's the after.
watsonrx13 |
Here's the before in the front fender.
watsonrx13 |
Here's the after.
watsonrx13 |
Mar 20 2005, 04:55 PM
I also cleaned and repainted my rear shocks and rear control arms.
Here's the before shocks. Attached image(s) |
watsonrx13 |
Here's the after.
watsonrx13 |
Mar 20 2005, 04:56 PM
And here's a shot of the control arm.
Hope everyone else had a productive and/or enjoyable weekend. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) Attached image(s) |
Porsche Rescue |
Mar 20 2005, 05:35 PM
Rob,
You are inspiring me. Never thought of removing the control arm with axle/hub intact. Seems like the easiest way. Once you unbolt the outer bracket is it as simple as removing the inner large nut and pulling the whole assembly off (after cv at tranny unbolted and caliper/disc removed)? |
watsonrx13 |
Mar 20 2005, 06:12 PM
Actually I removed the axle, control arm, shock, spring, caliper/disc as one unit.
Here's my web site with the steps I used. BTW, this was a suggestion by Brad.... |
URY914 |
Mar 20 2005, 06:20 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,389 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
You are good.
Gint |
Mar 20 2005, 07:03 PM
Mike Ginter Group: Admin Posts: 16,066 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Lookin good Rob.
Lo-Fi Version | Time is now: 5th May 2024 - 01:51 AM |
