Type 4 mechanical compression ratio, Why is the factory compression so low? |
Beebo Kanelle |
Feb 11 2016, 01:03 PM
Member Group: Members Posts: 248 Joined: 22-November 12 From: Houston, Texas Member No.: 15,177 Region Association: Southwest Region |
OK, here's a fun one for the novice to ponder and you experts to answer:
Why is the factory mechanical CR so low? and for reference, what is the highest mechanical CR that can be physically achieved? assume no octane limitations - I'm just looking for the design limit for the highest CR that can be / has been in a Type 4 engine using available technology. Thanks |
brant |
Feb 11 2016, 07:39 PM
914 Wizard Group: Members Posts: 11,626 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
The materials used in a stock 914 engine do not like high compression.
Water cooling provides more controlled cooling than does steel cylinders on an air cooled motor It's expensive to rebuild with modern components/nickies/etc additionally the metallurgy of the block/heads can play into high theoretical numbers |
ConeDodger |
Feb 11 2016, 09:06 PM
Apex killer! Group: Members Posts: 23,597 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
The materials used in a stock 914 engine do not like high compression. Water cooling provides more controlled cooling than does steel cylinders on an air cooled motor It's expensive to rebuild with modern components/nickies/etc additionally the metallurgy of the block/heads can play into high theoretical numbers (IMG:style_emoticons/default/agree.gif) engine sealing becomes an issue. Cylinder head temperatures become an issue. Oil cooling which is important to consider separately from CHT becomes an issue. Your numbers, 100 HP/liter are doable, but I know only a couple builders who can make that live very long. At the raw number, 200-210HP, you might as well put a 3.2-6 in it as you've spent the money... |
Lo-Fi Version | Time is now: 24th May 2024 - 02:16 PM |
