Type 4 mechanical compression ratio, Why is the factory compression so low? |
Beebo Kanelle |
Feb 11 2016, 01:03 PM
Member Group: Members Posts: 248 Joined: 22-November 12 From: Houston, Texas Member No.: 15,177 Region Association: Southwest Region |
OK, here's a fun one for the novice to ponder and you experts to answer:
Why is the factory mechanical CR so low? and for reference, what is the highest mechanical CR that can be physically achieved? assume no octane limitations - I'm just looking for the design limit for the highest CR that can be / has been in a Type 4 engine using available technology. Thanks |
brant |
Feb 11 2016, 07:39 PM
914 Wizard Group: Members Posts: 11,626 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
The materials used in a stock 914 engine do not like high compression.
Water cooling provides more controlled cooling than does steel cylinders on an air cooled motor It's expensive to rebuild with modern components/nickies/etc additionally the metallurgy of the block/heads can play into high theoretical numbers |
ConeDodger |
Feb 11 2016, 09:06 PM
Apex killer! Group: Members Posts: 23,597 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
The materials used in a stock 914 engine do not like high compression. Water cooling provides more controlled cooling than does steel cylinders on an air cooled motor It's expensive to rebuild with modern components/nickies/etc additionally the metallurgy of the block/heads can play into high theoretical numbers (IMG:style_emoticons/default/agree.gif) engine sealing becomes an issue. Cylinder head temperatures become an issue. Oil cooling which is important to consider separately from CHT becomes an issue. Your numbers, 100 HP/liter are doable, but I know only a couple builders who can make that live very long. At the raw number, 200-210HP, you might as well put a 3.2-6 in it as you've spent the money... |
Mark Henry |
Feb 11 2016, 09:20 PM
The materials used in a stock 914 engine do not like high compression. Water cooling provides more controlled cooling than does steel cylinders on an air cooled motor It's expensive to rebuild with modern components/nickies/etc additionally the metallurgy of the block/heads can play into high theoretical numbers (IMG:style_emoticons/default/agree.gif) engine sealing becomes an issue. Cylinder head temperatures become an issue. Oil cooling which is important to consider separately from CHT becomes an issue. Your numbers, 100 HP/liter are doable, but I know only a couple builders who can make that live very long. At the raw number, 200-210HP, you might as well put a 3.2-6 in it as you've spent the money... (IMG:style_emoticons/default/agree.gif) To a point ... 100hp/liter is a crack pipe dream for a novice Type 4 builder. A Type 4 is an unforgiving bitch that will granade if you don't build it right. Your pistons and cylinders alone will cost $3440, I'd say you are easily well over $12K in parts alone. I know look at my signature line for my '67 bug. If the price doesn't scare you then look at my sig line again and what's going into my 914. Once you get to the cost of a super HP Type 4 in a 914, you may as well do a nice /6. But then if HP is all you are looking for... do a V8. |
Lo-Fi Version | Time is now: 24th May 2024 - 08:04 PM |
