Type 4 mechanical compression ratio, Why is the factory compression so low? |
Beebo Kanelle |
Feb 11 2016, 01:03 PM
Member Group: Members Posts: 248 Joined: 22-November 12 From: Houston, Texas Member No.: 15,177 Region Association: Southwest Region |
OK, here's a fun one for the novice to ponder and you experts to answer:
Why is the factory mechanical CR so low? and for reference, what is the highest mechanical CR that can be physically achieved? assume no octane limitations - I'm just looking for the design limit for the highest CR that can be / has been in a Type 4 engine using available technology. Thanks |
Beebo Kanelle |
Feb 11 2016, 04:35 PM
Thank you one and all.
I'm afraid I wasn't clear enough in my original inquiry - I am modeling the Type 4 based upon other engines I have been involved with in the past. I am not, however, familiar enough with the air-cooled engine to know if there are any hidden constraints that are unique. I believe it is possible to increase the output to 100 - 110 hp / liter in a street driven, smooth idling engine of two valve design - but I know there are limits - and it appears that, without going to exotic extremes that the reasonable limits would be 13:1. Has anybody gone higher ? Any and all info is greatly appreciated Thanks for the input / advice / sage wisdom |
Bulldog9 |
Feb 11 2016, 10:11 PM
Senior Member Group: Members Posts: 705 Joined: 21-August 13 From: United States Member No.: 16,283 Region Association: MidAtlantic Region |
Thank you one and all. I'm afraid I wasn't clear enough in my original inquiry - I am modeling the Type 4 based upon other engines I have been involved with in the past. I am not, however, familiar enough with the air-cooled engine to know if there are any hidden constraints that are unique. I believe it is possible to increase the output to 100 - 110 hp / liter in a street driven, smooth idling engine of two valve design - but I know there are limits - and it appears that, without going to exotic extremes that the reasonable limits would be 13:1. Has anybody gone higher ? Any and all info is greatly appreciated Thanks for the input / advice / sage wisdom A few thoughts from a novice 1 time Type 4 builder. 100-110HP/liter is not doable in a N/A Type 4 without a SERIOUS cash infusion, unless perhaps it is an alcohol burning bracket racer you rebuild after every run. That's optimistic even for a modern N/A inline 4 street motor.... I have two liter+ motorcycles that make this kind of power, but at 8-10K and no torque. Not a problem to push 700lbs, big problem for a passenger car. I'm sure it can be done, and maybe has, but after spending the last 5 years watching, reading, learning and doing, I havent seen it..... The Type 4 is a different animal.. Do some reading and educate yourself. The CR is not really low for that era. 13:1 CR reasonable? you need to put down the crack pipe freind (IMG:style_emoticons/default/drooley.gif) |
Mark Henry |
Feb 11 2016, 10:35 PM
I'm sure it can be done, and maybe has, but after spending the last 5 years watching, reading, learning and doing, I havent seen it..... Jake says he's done it, closest I've come on a slightly milder 2.6L build is 70hp/liter, but you're totally right on outrageously expensive and not a novice build. Personally for the novice I'd start with a 2056cc build and if you are truly skilled a 2276cc would be the max. Both engines are great in a 914. BTW just a FYI a performance /6 build is way harder than a /4. BTDT |
Lo-Fi Version | Time is now: 18th May 2024 - 11:34 AM |
