Type 4 mechanical compression ratio, Why is the factory compression so low? |
Beebo Kanelle |
Feb 11 2016, 01:03 PM
Member Group: Members Posts: 248 Joined: 22-November 12 From: Houston, Texas Member No.: 15,177 Region Association: Southwest Region |
OK, here's a fun one for the novice to ponder and you experts to answer:
Why is the factory mechanical CR so low? and for reference, what is the highest mechanical CR that can be physically achieved? assume no octane limitations - I'm just looking for the design limit for the highest CR that can be / has been in a Type 4 engine using available technology. Thanks |
Mueller |
Feb 12 2016, 12:16 PM
You really cannot model the Type IV using past motor builds, completely different designs...bore, stroke, combustion chamber, port shapes and flows.
What worked on your Chevy might not work here. I seriously doubt you are going to come up with magical engine recipe that hasn't been tried before. |
Lo-Fi Version | Time is now: 24th May 2024 - 03:17 PM |
