914/6 replacement for rear axes / guiding arm rubbers ? |
IAA1963 |
Feb 11 2016, 02:23 PM
Newbie Group: Members Posts: 46 Joined: 8-October 11 Member No.: 13,652 Region Association: None |
Hi,
The rubbers of the rear axes / guiding arms of my /6 are worn and I would like to change them. There is no part number in the Porsche Parts Cataloge and these were not offered as spare Part from the Factory. I know that these are available for track purposes, but I want to have an original softer version. Any hints where I can get these? Thanks, Mark |
TheCabinetmaker |
Feb 11 2016, 02:29 PM
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Used to be available from factory in the new trailing arm assembly.
mepstein |
Feb 11 2016, 02:34 PM
914-6 GT in waiting Group: Members Posts: 19,252 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Ask Eric Shea at Pmbperformance if elephant rubber bushings are an exact match. I think they are.
shoguneagle |
Feb 12 2016, 01:19 AM
shoguneagle Group: Members Posts: 1,180 Joined: 3-January 03 From: CA, OR, AZ (CAZOR); New Mexico Member No.: 84 Region Association: Northern California |
I have Elephant Racing equipment on my 914 rear suspension so they do fit; I also have the Elephant Racing equipment on my 911 Carrera front. Bronze/brass therefore a little expensive but do have zert fittings for greasing. I like them.
The only other ones I ran across where the plastic/delrin(?) type which are probably the ones being mentioned for racing. I have seen threads on using these and putting zert fittings in after cutting grease channels. The grease channels should make the suspension mover without any positional sticking. Run a search to determine if the regular rubber ones are available and for procedures since they were also mentioned in the threads. Steve |
Andyrew |
Feb 12 2016, 01:38 AM
Understand that "racing" versions will actually be softer riding than the factory and offer better precision of the rear suspension.
The trailing arm has freer movement with the newer bushings and has almost 0 flex in it and therefore provides a smoother and better handling car. I would go with the elephant racing bushings if I didnt already have needle roller bearings on all 4 corners. |
Lo-Fi Version | Time is now: 2nd May 2024 - 06:40 AM |
