trailing arm bushing install |
Amphicar770 |
Feb 11 2016, 11:47 PM
Senior Member Group: Members Posts: 1,192 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
OK, finally starting to put things back together. New bearings went into freshly powder coated trailing arms this evening.
I then went to install the new rubber bushings and pivot shaft from Elephant Racing and here is where I am running into problems even with their tool set. Per their instructions you set the bushings in the trailing arm and then using a pipe clamp and the provided tools, you soap the heck out of the parts and insert the pivot shaft through the one bushing and push it all the way through with pressure from the pipe clamp. Works well for the first few inches until the pivot shaft starts pulling the bushing down through the trailing arm. Getting everything back out was not fun, could only do it using my press. In watching a redneck video His description) the guy seems to put the pivot shaft on first and then push the bushings in at both ends. First seems to go easy, second he helps along with a hammer and a tool to fit over the bushing. Anyway, suggestions on best approach welcomed. I really figured that by paying a premium for the set with the tools that this would be simple. Arrrgh. Thanks, Mike |
veekry9 |
Feb 14 2016, 12:57 AM
OldMember Group: Retired Members Posts: 3,068 Joined: 17-June 13 From: TO Member No.: 16,025 Region Association: Canada |
I have to say it.
Danger, without caution,the use of a press may lead to serious injury or death. Case in point:2009 A fellow longtime employee was struck in the head by part that had "kicked" out of the heavy press(100Ton version). Off for a year to heal and recuperate,he later told me how close it was,a heavy blow that knocked him unconscious. A proper seat and mandrel,or cup 'must' be used. A wood plank is wrong. The use of a nut with a plate welded to it is safer,a metal plate with a seat machined into it is safer. Industrial Safety 101. / |
Lo-Fi Version | Time is now: 22nd May 2024 - 12:12 PM |
