trailing arm bushing install |
Amphicar770 |
Feb 11 2016, 11:47 PM
Senior Member Group: Members Posts: 1,191 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
OK, finally starting to put things back together. New bearings went into freshly powder coated trailing arms this evening.
I then went to install the new rubber bushings and pivot shaft from Elephant Racing and here is where I am running into problems even with their tool set. Per their instructions you set the bushings in the trailing arm and then using a pipe clamp and the provided tools, you soap the heck out of the parts and insert the pivot shaft through the one bushing and push it all the way through with pressure from the pipe clamp. Works well for the first few inches until the pivot shaft starts pulling the bushing down through the trailing arm. Getting everything back out was not fun, could only do it using my press. In watching a redneck video His description) the guy seems to put the pivot shaft on first and then push the bushings in at both ends. First seems to go easy, second he helps along with a hammer and a tool to fit over the bushing. Anyway, suggestions on best approach welcomed. I really figured that by paying a premium for the set with the tools that this would be simple. Arrrgh. Thanks, Mike |
N_Jay |
Sep 18 2016, 09:17 AM
Member Group: Members Posts: 283 Joined: 2-March 16 From: Chicago NW Burbs Member No.: 19,720 Region Association: None |
So the question becomes:
Doing a roadworthy restoration, should the bushings be replaced? How can you tell bad from good? Are hard "race" (not rubber) bushings a better choice for the shade-tree mechanic? |
Lo-Fi Version | Time is now: 21st May 2024 - 11:37 PM |
