> trailing arm bushing install
Amphicar770
post Feb 11 2016, 11:47 PM
Post #21
OK, finally starting to put things back together. New bearings went into freshly powder coated trailing arms this evening.
I then went to install the new rubber bushings and pivot shaft from Elephant Racing and here is where I am running into problems even with their tool set.
Per their instructions you set the bushings in the trailing arm and then using a pipe clamp and the provided tools, you soap the heck out of the parts and insert the pivot shaft through the one bushing and push it all the way through with pressure from the pipe clamp.
Works well for the first few inches until the pivot shaft starts pulling the bushing down through the trailing arm. Getting everything back out was not fun, could only do it using my press.
In watching a redneck video His description) the guy seems to put the pivot shaft on first and then push the bushings in at both ends. First seems to go easy, second he helps along with a hammer and a tool to fit over the bushing.
Anyway, suggestions on best approach welcomed. I really figured that by paying a premium for the set with the tools that this would be simple. Arrrgh.
Thanks,
Mike
Amphicar770   trailing arm bushing install   Feb 11 2016, 11:47 PM
Olympic 1.7   :popcorn: I'll be doing this soon myself.   Feb 12 2016, 07:22 AM
veekry9   Hot and slippery,is how the rubbers go in! Rea...   Feb 12 2016, 07:48 AM
Amphicar770   Thanks. I'll give the boiling oil a try. It...   Feb 12 2016, 12:33 PM
The Cabinetmaker   Powder coating can be really thick, and it's t...   Feb 12 2016, 12:55 PM
ndfrigi   I believed Eric-PMB mentioned on another thread th...   Feb 12 2016, 01:18 PM
DavidSweden   I just installed Elephant rear bushing today. I al...   Feb 13 2016, 12:07 PM
Amphicar770   This evening I removed the powder coat from where ...   Feb 13 2016, 10:33 PM
veekry9   I have to say it. Danger, without caution,the use ...   Feb 14 2016, 12:57 AM
Amphicar770   One more tip on removing powder coat. For the sec...   Feb 14 2016, 11:37 AM
mepstein   One more tip on removing powder coat. For the se...   Feb 14 2016, 11:42 AM
Amphicar770   OK, I am staring to think that there may be a flaw...   Feb 14 2016, 02:14 PM
DavidSweden   Yes I had the same problem. when I did the second...   Feb 14 2016, 02:39 PM
Amphicar770   Yeah, this is really turning into a huge time wast...   Feb 14 2016, 05:17 PM
DavidSweden   Yeah, this is really turning into a huge time was...   Feb 14 2016, 05:43 PM
MikeM   This seems way too difficult. Please let us know w...   Feb 14 2016, 05:24 PM
Amphicar770   I did not want to deal with it anymore last night ...   Feb 15 2016, 10:26 AM
DavidSweden   I did not want to deal with it anymore last night...   Feb 15 2016, 11:14 AM
Nutter965   Oh boy, i've just pressed out my old bushings ...   Feb 15 2016, 11:27 AM
Amphicar770   Oh boy, i've just pressed out my old bushings...   Feb 15 2016, 12:43 PM
914_teener   Did you guys mic the inside of the trailing arm to...   Feb 15 2016, 12:58 PM
Amphicar770   Aw, damn. I spoke to soon on last message which I...   Feb 15 2016, 01:16 PM
Amphicar770   I just received a reply from Elephant Racing. The...   Feb 15 2016, 01:33 PM
BeatNavy   I just went through this process this weekend. I ...   Sep 17 2016, 05:21 PM
raynekat   I just went through this process this weekend. I...   Sep 17 2016, 06:32 PM
N_Jay   So the question becomes: Doing a roadworthy resto...   Sep 18 2016, 09:17 AM
- Lo-Fi Version Time is now: 17th July 2025 - 05:24 AM
