Oil Leak at Push Rod Tube, How to Fix this in the car? |
HappyTrails |
Feb 13 2016, 03:00 PM
Newbie Group: Members Posts: 10 Joined: 4-November 15 From: California central coast Member No.: 19,328 Region Association: None |
While installing new headers the stub pipe at number 1 cylinder contacted against the push rod tube and it now leaks oil at the cylinder head end.
I have installed push rod tubes on an engine out of the car, but what are the options for fixing a leak in this location in situ? Big boo boo. |
RohJay |
Feb 14 2016, 12:14 AM
Member Group: Members Posts: 189 Joined: 24-April 07 From: Colombo, SRI LANKA Member No.: 7,689 |
At the risk of sounding redundant, make sure you have the Pushrod Tube Retaining Clips. Mine simply didn't have the clips. I went through several tube seal replacements before I even realized there such a thing.
ThePaintedMan |
Feb 14 2016, 09:43 AM
Advanced Member Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
At the risk of sounding redundant, make sure you have the Pushrod Tube Retaining Clips. Mine simply didn't have the clips. I went through several tube seal replacements before I even realized there such a thing. And on that note, MAKE SURE you consult pictures of the spring properly installed. I did pushrod tubes in the car and thought I had it right. Unfortunately one portion of the spring was rubbing on a pushrod tube. Within about 1000 miles I developed a backfire from the #3 cylinder. I ended up pulling the engine only to find out that the groove worn into the pushrod was actually allowing the retainer spring to put just enough pressure on it to keep the valve closed at higher RPMs. (IMG:style_emoticons/default/headbang.gif) |
Lo-Fi Version | Time is now: 19th May 2024 - 08:13 AM |
