A Frayed Clutch Cable Screwed Up My Day |
Larmo63 |
Feb 13 2016, 05:58 PM
Advanced Member Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
Right after I bought my latest '73 914, I went to adjust the clutch and I noticed the cable was a bit frayed. I ordered the stuff from Pelican, it's not here and I tempted fate. Well, it broke on the way home today from cars 'n coffee and it made for an interesting and frustrating afternoon. Of course, all the cable end parts are gone too, and I couldn't find anything in the street. More to order from Pelican.
Moral of the story: inspect your clutch cable routinely, and if it is AT ALL coming apart, it's GOING to break. (IMG:style_emoticons/default/headbang.gif) |
Dave_Darling |
Feb 13 2016, 09:52 PM
Larmo, a couple of zip ties can hold the end of the cable onto the throwout arm. That should (in theory) keep it from going anywhere if the cable breaks.
Ndfrigi, your problem is in the ignition circuit, the tach going crazy indicates that. It may be as simple as the points getting unplugged! Time to check in your distributor. You can also unplug the tach signal wire (black/purple) from the coil's (-) terminal to see if there's a short there causing a lack of spark. --DD |
rgalla9146 |
Feb 16 2016, 09:10 PM
Advanced Member Group: Members Posts: 4,560 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Larmo, a couple of zip ties can hold the end of the cable onto the throwout arm. That should (in theory) keep it from going anywhere if the cable breaks. Ndfrigi, your problem is in the ignition circuit, the tach going crazy indicates that. It may be as simple as the points getting unplugged! Time to check in your distributor. You can also unplug the tach signal wire (black/purple) from the coil's (-) terminal to see if there's a short there causing a lack of spark. --DD As I read about Larmos broken clutch cable I thought the same thing as you Dave. The problem is not just the broken cable but also the missing trunion and special nuts. We need some kind of loose safety wire devise to keep the parts from scattering. Or maybe a short, soft rubber leash attached to the pulley side of the adjustment end. |
Mikey914 |
Feb 17 2016, 10:29 AM
The rubber man Group: Members Posts: 12,671 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Larmo, a couple of zip ties can hold the end of the cable onto the throwout arm. That should (in theory) keep it from going anywhere if the cable breaks. Ndfrigi, your problem is in the ignition circuit, the tach going crazy indicates that. It may be as simple as the points getting unplugged! Time to check in your distributor. You can also unplug the tach signal wire (black/purple) from the coil's (-) terminal to see if there's a short there causing a lack of spark. --DD As I read about Larmos broken clutch cable I thought the same thing as you Dave. The problem is not just the broken cable but also the missing trunion and special nuts. We need some kind of loose safety wire devise to keep the parts from scattering. Or maybe a short, soft rubber leash attached to the pulley side of the adjustment end. Got those pretty inexpensively http://www.shop.914rubber.com/Clutch-cable...m?categoryId=-1 http://www.shop.914rubber.com/7mm-Nut-for-...m?categoryId=-1 For $6.40 worth of hardware may not be worth the effort Complete set up http://www.shop.914rubber.com/Clutch-cable...ing-GB-CCBP.htm |
Lo-Fi Version | Time is now: 24th May 2024 - 06:19 PM |
