Mark's (914Rubber) Project Car |
cary |
Feb 24 2016, 01:57 AM
Advanced Member Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest |
I've been asked by Mark to do some sheet metal/body work on his 75 2.0 Liter project car. The car arrived last Monday. But I needed to finish up a couple things on my project car and in my shop first. But I dove in this afternoon.
First task is to tidy things up after the paint stripping. Which included dropping the engine in order remove any residual media in the nooks and crannies. I was concerned with the rust prevention product that Dustless Blaster mixes with the glass media being left on and in the electrical connections. I'm a firm believer of an ounce of prevention is worth a pound of cure. I dribbled some OSPHO on a couple connectors in my white car. Not good. It ate the crap out the plating. Here's Super In Law working on loosening up the media in order to blow it off. It will need to be steam cleaned. Project List : So Far Replace rear panel Replace rear trunk floor pan Replace back half of floor pan ............... Mark I'll send you pictures Misc. hammer and dolly work A few misc. patch panels R&R both jack points and posts This is like a new car compared to my project ............... Observations : Suspension Consoles look great and seem to be virgin. Same with the motor mounts Battery tray was changed at some time in its life Back engine tray is bent to hell .............pushed up Hell hole is filled with caked in blast media. Stopping at Sears on the way home for a new filter for my vacuum. I'll look closely for prior repairs. Both the lower longs look great at first glance Needing more research : A few rust pits on the upper right outer wheelhouse long But we also a have fairly good sized rust spot a little further up the upper long. Right next to the suspension console. These are both in the double walled section of the upper long. |
cary |
Mar 1 2016, 08:34 AM
Now on to the task at hand ............ continuing with the rear trunk removal.
I start the day with removing the rear trunk reinforcement. http://www.restoration-design.com/store/product/PP335A I was thinking we'd be able to reuse that part. Look at how nice and shiny it is on the topside. After removal. Not So Much ............... for $25 it's not worth the risk. Even with OSPHO and POR15, not worth the chance. After removing that part I decided that we'll move to plan B and replace the entire trunk piece. Lesson Learned : Remove plate 1st to do your assessment. No time lost, because of the 75-76 bumper support I'd remove it the same way, in pieces. Removing the remaining material off the back of the transmission support was pretty simple. I once again rolled it like a tin can. What I did learn. The floor pan is only spot welded in a couple spots UNDER the reinforcement. Then the top spot welds go thru all three pieces. So you just roll the material until you hit the next spot weld. Then give the already drilled out spot weld a just a little and roll on to the next one. Tomorrow (today) I'll finish the right bumper support area. Probably no new pictures unless something exciting happens. I'll not cut out the remaining portion over the transmission support until I have the new part in my hand. Rob (Beatnavy), I'm still on the same 3/8 Rotacut spot weld cutter head. (IMG:style_emoticons/default/smile.gif) Using a lot of cutting oil. Which is making a mess, but cleans right up with House of Color Wipe Out wax and grease remover. |
BeatNavy |
Mar 2 2016, 04:41 AM
Certified Professional Scapegoat Group: Members Posts: 2,924 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
Rob (Beatnavy), I'm still on the same 3/8 Rotacut spot weld cutter head. (IMG:style_emoticons/default/smile.gif) Using a lot of cutting oil. Which is making a mess, but cleans right up with House of Color Wipe Out wax and grease remover. I'm glad you're having good luck with it too! Getting spot welds out is "fun" enough that you don't need to deal with a lousy cutter that keeps breaking. I'm working a on a driver's side long now... Fun just came to a screeching halt ............... (IMG:style_emoticons/default/barf.gif) What you can't see is the HUGE mouse nest inside the wheelhouse ............... This probably the best example I've ever seen of these cars rusting from the inside out. These kind of took the wind out of my sails. Uh-oh. (IMG:style_emoticons/default/sad.gif) Yes, I know that feeling... |
Lo-Fi Version | Time is now: 21st May 2024 - 04:25 PM |
