Mark's (914Rubber) Project Car |
cary |
Feb 24 2016, 01:57 AM
I've been asked by Mark to do some sheet metal/body work on his 75 2.0 Liter project car. The car arrived last Monday. But I needed to finish up a couple things on my project car and in my shop first. But I dove in this afternoon.
First task is to tidy things up after the paint stripping. Which included dropping the engine in order remove any residual media in the nooks and crannies. I was concerned with the rust prevention product that Dustless Blaster mixes with the glass media being left on and in the electrical connections. I'm a firm believer of an ounce of prevention is worth a pound of cure. I dribbled some OSPHO on a couple connectors in my white car. Not good. It ate the crap out the plating. Here's Super In Law working on loosening up the media in order to blow it off. It will need to be steam cleaned. Project List : So Far Replace rear panel Replace rear trunk floor pan Replace back half of floor pan ............... Mark I'll send you pictures Misc. hammer and dolly work A few misc. patch panels R&R both jack points and posts This is like a new car compared to my project ............... Observations : Suspension Consoles look great and seem to be virgin. Same with the motor mounts Battery tray was changed at some time in its life Back engine tray is bent to hell .............pushed up Hell hole is filled with caked in blast media. Stopping at Sears on the way home for a new filter for my vacuum. I'll look closely for prior repairs. Both the lower longs look great at first glance Needing more research : A few rust pits on the upper right outer wheelhouse long But we also a have fairly good sized rust spot a little further up the upper long. Right next to the suspension console. These are both in the double walled section of the upper long. |
cary |
Mar 4 2016, 12:42 AM
Here's a better shot of the wheelhouse with the fender and door jam removed. Lined out areas are rusted thru.
It' a shame this happened. Here's a shot of the wheel house above the suspension mount. Virgin. I still contend this was caused by the seam sealer on the top rail being removed and not replaced. (IMG:style_emoticons/default/mad.gif) I'd still like to try sliding the inner layer behind the suspension mount. It would be some tricking welding. Might have to buy some special arc welding rod to tack it in. Would have to build some turnbuckle gadgets to push it up tight so it could be welded. But I like a challenge. That's how I roll. But the anal part of my brain says the weld will be too close and too big next to the suspension mount. So the mount and its dreaded tie will have to be removed so it can be patched correctly. (IMG:style_emoticons/default/sad.gif) Plus it we give a better view of the condition of the upper inner long. This will entail building a fixture for aligning the mount when we reinstall it. This as far as we go without having the new part in my hand for measurements ................ |
Lo-Fi Version | Time is now: 21st May 2024 - 08:54 PM |
