Mark's (914Rubber) Project Car |
cary |
Feb 24 2016, 01:57 AM
Advanced Member Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest |
I've been asked by Mark to do some sheet metal/body work on his 75 2.0 Liter project car. The car arrived last Monday. But I needed to finish up a couple things on my project car and in my shop first. But I dove in this afternoon.
First task is to tidy things up after the paint stripping. Which included dropping the engine in order remove any residual media in the nooks and crannies. I was concerned with the rust prevention product that Dustless Blaster mixes with the glass media being left on and in the electrical connections. I'm a firm believer of an ounce of prevention is worth a pound of cure. I dribbled some OSPHO on a couple connectors in my white car. Not good. It ate the crap out the plating. Here's Super In Law working on loosening up the media in order to blow it off. It will need to be steam cleaned. Project List : So Far Replace rear panel Replace rear trunk floor pan Replace back half of floor pan ............... Mark I'll send you pictures Misc. hammer and dolly work A few misc. patch panels R&R both jack points and posts This is like a new car compared to my project ............... Observations : Suspension Consoles look great and seem to be virgin. Same with the motor mounts Battery tray was changed at some time in its life Back engine tray is bent to hell .............pushed up Hell hole is filled with caked in blast media. Stopping at Sears on the way home for a new filter for my vacuum. I'll look closely for prior repairs. Both the lower longs look great at first glance Needing more research : A few rust pits on the upper right outer wheelhouse long But we also a have fairly good sized rust spot a little further up the upper long. Right next to the suspension console. These are both in the double walled section of the upper long. |
cary |
Mar 17 2016, 08:19 PM
Ok, now back to documenting Wednesday's work.
Now we move to positioning the rear panel ............. 1st., I opt to spread open the middle channel on the left side. No particular reason. After a test fit I decide I'll need to trim a bit off the right side. I proceed to slide the left side in as much as I could. I did need to trim a bit of the excess off the tub flange under the trunk seal channel. This allowed me additional movement to the left. There she is. A little persuasion with a wood block against the latch support and she slid into place. (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) Here's a shot of the right side channel. Looks like I cut on the wrong side of the line. (IMG:style_emoticons/default/sad.gif) All Clecoed in and ready to start welding. |
Lo-Fi Version | Time is now: 21st May 2024 - 10:58 AM |
