900.187.018.02, Hex Head Tapping Screw |
Posts in this area are restricted to the following format. If you have a general question, please post it in the Garage.
1. All new threads MUST be titled with a part number only. (i.e. 901.351.801.17)
2. Thread description should be an english description of the part. (i.e. Brake Dust Shields)
3. Replies to the thread are only restricted by pertinence. Some examples are original finish of the part (painted, cad plated, etc), common failures (cracking at the mount points), repair information or tips, pictures (stock or custom), upgrades, etc.
If you have any questions regarding the rules of this forum, please PM McMark.
McMark |
Mar 1 2016, 01:05 PM
900.187.018.02
Hex Head Tapping Screw B 4,8 x 16 Material: Steel, gold zinc plated Hex head width across flats: 8mm Head thickness: 2.93mm Head is recessed ~0.5mm Recess diameter ~7mm Thread pitch: ~1.44mm Pointed tip, threaded all the way to the tip Attached image(s) |
McMark |
Mar 1 2016, 01:08 PM
Nearest replacement I've found:
Fastenal #0173112 Head is nearly identical, they're slightly longer and the thread pitch is wrong (~2mm). Also, threads are deeper cut. Attached image(s) |
McMark |
Mar 1 2016, 02:31 PM
Apparently still available from Porsche as well.
http://www.stoddard.com/90018701802.html (IMG:http://www.914world.com/bbs2/uploads_offsite/www.stoddard.com-419-1456864319.1.jpg) |
Lo-Fi Version | Time is now: 17th May 2024 - 03:27 PM |
