Altenator modification, Wild eyed idea |
Joe Ricard |
Mar 24 2005, 07:26 AM
So my co-worker and I just had a wild idea. how hard would it be or better yet can I unplug the voltage regulator during and autocross run without hurting anything?
Benefits would be the altenator is free-wheeling vs stealing a couple HP. Should help acceleration too???? |
TheCabinetmaker |
Mar 24 2005, 07:39 AM
Why not pull the belt? Should take 2 minutes.
Joe Ricard |
Mar 24 2005, 07:46 AM
Because pulling the plug is 2 seconds. and I got the belt the right tension so I would rather leave it.
iiibdsiil |
Mar 24 2005, 07:50 AM
Needs Door Locks Group: Members Posts: 605 Joined: 19-November 03 From: Tampa / Boca Raton, FL Member No.: 1,362 |
I doubt it steals enough HP to make it worth it. Well, 2 seconds, it might be worth it, but might end up being worse because of the voltage change, and not providing as much power to the coil?
TheCabinetmaker |
Mar 24 2005, 07:51 AM
Ok, but how does unpluging the regulator decrease the work the engine does to turn the alt? They don't have a clutch like an AC compressor. Don't they spin the same no matter what the VR does?
iiibdsiil |
Mar 24 2005, 07:54 AM
The more amps you are pulling the harder the alternator has to work, and puts more pull on the engine.
URY914 |
Mar 24 2005, 07:55 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,356 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
You would save about .00001 HP.
But hey, we need all the help we can get. |
Joe Ricard |
Mar 24 2005, 08:45 AM
Paul not sure that is true. How much power is requires to spin an altenator making 15 or 20 amps which is charging the battery, running fuel pump, CD ignition box brief brake lights (anything else)? Oh, gauges ! Next to just spinning the alt under no load which I agree is .0001 hp.
URY914 |
Mar 24 2005, 09:00 AM
OK, maybe .1 HP. Will you ever feel it?
Make two autox runs. One with the alternater hooked up and one without. Did you turn a faster time without? On a stock car I would doubt it. BTW, Joe I layed up one of your passenger door last weekend. It's curing in the sunshine. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Paul |
brant |
Mar 24 2005, 09:52 AM
914 Wizard Group: Members Posts: 11,619 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Joe,
I don't remember the wiring schematics at the moment. but its sort of like a racing kill switch... The alternator current has to have a method of winding down throught a resistor and ground in order to not burn out the diodes. but yes it can be done. I once started the project (never finished it) on an old car. we had a hidden switch in the engine bay underneath the regulator panel. |
URY914 |
Mar 24 2005, 10:00 AM
What I mean by a stock car is that is would have more effect on a lightweight car (mine) or a modified car (yours).
Big fat heavy stock car you wouldn't notice that much. |
lapuwali |
Mar 24 2005, 10:54 AM
The actual HP loss is easy to calculate. Ignition is about 3 amps. The fuel pump is about 4 amps. The injection system is another 3 amps. Let's say that's all that's running. 10 amps @ 14v is 140W. 746W in 1hp. The alternator is roughly 50% efficient, so it's consuming 280W, or 0.38hp. More than Paul's guesstimate, but still not enough to make any difference. The stock alternator running full bore will consume about 2hp. You don't need to pull the regulator. Just pull the field wire (the one that runs through the G bulb in the dash). Put a switch there, and the alternator will be disabled when it's off. No current generated, so no worries about melting any diodes in it. |
Joe Ricard |
Mar 24 2005, 03:45 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) That's a good idea. Pull the Gen bulb and see if the alt is charging @ the battery.
If it works then I'll put in a switch. Certainly can't harm the altenator if I am just simulating a burnt bulb. So the excitiation voltage goes throught the bulb just like my 928. Cool! (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) Hey if you aren't cheating you aren't trying. If you aren't trying you aren't learning what not to do next time..... (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif) |
lapuwali |
Mar 24 2005, 03:56 PM
Just like your 928, and pretty much every charging system made in the last 50 years. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Still, you're not going to do enough good to offset even this minor effort, IMHO. Less than 1/2hp is awfully small. |
Flat VW |
Mar 24 2005, 04:00 PM
Illegal Soapbox Derby Racecar Group: Members Posts: 1,692 Joined: 13-November 04 From: Phoenix, AZ Member No.: 3,105 |
URY - who you callin' FAT? (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif) Joe, losing five pounds by cutting out the fried foods and the soda would have a greater effect. (IMG:http://www.914world.com/bbs2/html/emoticons/lol2.gif) I've got a Weight Watcher's meeting in fifteen minutes, gotta go! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) John (IMG:http://www.914world.com/bbs2/html/emoticons/spam.gif) P.S. and watch the after dinner snacks too (IMG:http://www.914world.com/bbs2/html/emoticons/beer3.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/chowtime.gif) |
Joe Ricard |
Mar 24 2005, 04:02 PM
Well maybe, pulling the belt would probably be better allowing the engine to spin up faster. 1978 lbs and a 12 lb flywheel it's just gotta be worth something and it won't cost Nuthin. Thats the best part (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif)
Brad Roberts |
Mar 24 2005, 04:05 PM
On a injected car... losing the alt is a kick in the pants. It is certainly more than 1hp when you turn the alternator off. I used the switch method in the past. Very easy. I switched it at the regulator plate. Turned the alt off right before timed runs in PCA time trial series (3 laps)
B |
Joe Ricard |
Mar 24 2005, 04:14 PM
Thanks Brad, Thats what I am looking for. 44 IDF's 86b cam and ported 2.0L heads already are a kick in the pants. This is the kinda thing that will keep me ahead of my son when he co-drives (IMG:http://www.914world.com/bbs2/html/emoticons/lol2.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/flipa.gif)
lapuwali |
Mar 24 2005, 04:23 PM
Hm... If so, then the stock alternator is considerably less efficient than most. OR, a completely different effect: D-Jet has very poor adjustment for battery voltage fluctuations, which have a substantial effect on mixture due to changes in injector opening times. Counter-intuitively, a lower battery voltage means a richer mixture. With no alternator, system voltage will be 12.5v (more or less) rather than 13.5-14v, since that's what the battery is putting out by itself. This is why a bad or marginal voltage regulator can have a significant effect on mixture with D-Jet. Perhaps the "kick in the pants" you're feeling isn't caused by losing the alternator drag, but rather by a richer fuel mixture across the board caused by the lower system voltage. |
Lo-Fi Version | Time is now: 4th May 2024 - 02:26 PM |
