FS: NOS VDO Electrical Parts, Oil Pressure Temp Sender, Dual Pole Pressure Sender, Fuse Block |
914Sixer |
Mar 13 2016, 06:25 PM
NOS Electrical Prices Shipped. Genuine VDO.
Fuse Block (added used clips for mounting) $37 shipped Taco Plate Oil Temp Senders( will work with 911 or 914 temp gauge) $33 each shipped Dual Pole 0-80 PSI Oil Temp Sender $43 shipped Dual Pole 70-74 Master Cylinder Switch $22 shipped Paypal: a914nut@email.com Attached image(s) |
reharvey |
Mar 13 2016, 06:37 PM
Senior Member Group: Members Posts: 573 Joined: 16-July 08 From: N. E. Ohio Member No.: 9,308 Region Association: North East States |
I'll take the oil pressure sender. Ray
914Sixer |
Mar 13 2016, 06:50 PM
Pressure sender going to Ray
porschetub |
Mar 14 2016, 12:58 PM
Advanced Member Group: Members Posts: 4,701 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
NOS Electrical Prices Shipped. Genuine VDO. Fuse Block (added used clips for mounting) $37 shipped Taco Plate Oil Temp Senders( will work with 911 or 914 temp gauge) $33 each shipped Dual Pole 0-80 PSI Oil Temp Sender $43 shipped Dual Pole 70-74 Master Cylinder Switch $22 shipped Paypal: a914nut@email.com I'll take the fuseboard,thanks. |
914Sixer |
Mar 14 2016, 03:54 PM
Fuse block sold to Garland. He sent a PM before Porschetub responded.
914Sixer |
Mar 14 2016, 05:27 PM
Temperature senders sold pending PP. Double pole master cylinder switch still available.
Garland |
Mar 14 2016, 10:23 PM
Restoration Fanatic Group: Members Posts: 1,329 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest |
Lo-Fi Version | Time is now: 18th May 2024 - 11:48 PM |
