Was ITB size for 2270 motor Now Single plenum 2270 |
cgnj |
Mar 15 2016, 03:41 PM
Senior Member Group: Members Posts: 623 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None |
I have been running 45 dells on 2270 with 34mm vents. Not sure if it was the cam choice (163/86b0, but it was much easier to drive with than with the 38/39 vents.
I was going to gut my spare dells for this project, but I think they are worth more in the box. So, for street 2270 what size motorcycle from wich bike tb should I be looking at for a first build? Thanks in advance, Carlos |
Mark Henry |
Mar 16 2016, 10:37 AM
You know the one thing I would do if I had a T4 (your size, 2270) 914 again would be to modify a a D-jet intake for a single mustang 75mm TB. Then drive it and learn how to tune the FI system.
I know for sure it would be easier to tune and you could take your time building an ITB system for later while still driving. I did this on my first build with a 2.0, mild cam and all stock intake (stock 914 TB). I admit it was the smoothest, most stock like operating system I've ever built. Systems...I've done a few stock engines like this. I know Jake doesn't like a single because you lose some HP, but to me sometimes it's worth it. Programmable FI is a steep learning curve and it would be one less thing in the mix while you are learning. |
Lo-Fi Version | Time is now: 18th May 2024 - 01:43 AM |
