Was ITB size for 2270 motor Now Single plenum 2270 |
cgnj |
Mar 15 2016, 03:41 PM
Senior Member Group: Members Posts: 623 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None |
I have been running 45 dells on 2270 with 34mm vents. Not sure if it was the cam choice (163/86b0, but it was much easier to drive with than with the 38/39 vents.
I was going to gut my spare dells for this project, but I think they are worth more in the box. So, for street 2270 what size motorcycle from wich bike tb should I be looking at for a first build? Thanks in advance, Carlos |
Jake Raby |
May 28 2016, 09:43 PM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
I played around with this a good bit in 2003-05. I found that unless the plenum capacity was at least 75% of the swept volume of the engine, that you'd lose big power with a plenum. This was despite the size of the TB thats used.
I also found that the plenums radically effect camshaft selection. Idle and low speed performance were greatly impacted when using the cams that work best with ITBs and carbs for us. I had to alter lobe separation to increase the vacuum signal, and make the engine run down low. I was never pleased with it, way too many compromises for me. |
Lo-Fi Version | Time is now: 22nd May 2024 - 05:37 AM |
