Quiet Down A Dual Carb Engine..It Works, Honda Goldwing 1200 Air Boxes....Sound Clips |
7TPorsh |
Mar 16 2016, 11:13 AM
Finally fixed my exhaust leak so a little more quiet but my carbs scream!
I have seen the expensive airbox for sale around $900 but has anyone found any other solution? I am thinking of using the Turbo Hats and running the input tube bellow the engine tin to a cone filter. Or are there any type of plastic molded airboxes out there that I can graft the weber bottom plate to? Running the open K&N filter housings. Ideas? |
Mar 16 2016, 11:33 AM
Resident German Group: Admin Posts: 41,607 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
rgolia |
Mar 16 2016, 11:38 AM
GeoJoe Group: Members Posts: 704 Joined: 5-February 10 From: PA Member No.: 11,329 Region Association: North East States |
Gary,
The CSP airbox I recently installed was $750 shipped. What a difference. I would think you could make something up similar for a lot less, but it will take some work. I do not know if you looked at my thread, but it really looks nice. |
7TPorsh |
Mar 16 2016, 12:11 PM
Gary, The CSP airbox I recently installed was $750 shipped. What a difference. I would think you could make something up similar for a lot less, but it will take some work. I do not know if you looked at my thread, but it really looks nice. Yes it looks awesome but a little too much $$$. Hoping there are existing boxes out there that could be modified. Maybe the air filter housing off an injected car. |
Mar 16 2016, 12:17 PM
Custom Member Group: Members Posts: 24,570 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
two CB Performance turbo hats for the carbs.
One mid 70's VW beetle air filter box. Some 3 inch plastic tubing. Similar to the CSP box, you can make one that does the same thing. The turbo hats go on the carbs (duh) The tubing needs to be drilled into the side of the beetle airbox, then clamped to the turbo hats. What you gain is noise reduction, and if you look around, this has been done before. I have no clue where the links are...but I did find it years ago when I had sticker shock regarding the CSP airbox solution. rich |
wes |
Mar 16 2016, 12:23 PM
wes Group: Members Posts: 1,588 Joined: 8-December 07 From: Ukiah Ca Member No.: 8,436 Region Association: Northern California |
two CB Performance turbo hats for the carbs. One mid 70's VW beetle air filter box. Some 3 inch plastic tubing. Similar to the CSP box, you can make one that does the same thing. The turbo hats go on the carbs (duh) The tubing needs to be drilled into the side of the beetle airbox, then clamped to the turbo hats. What you gain is noise reduction, and if you look around, this has been done before. I have no clue where the links are...but I did find it years ago when I had sticker shock regarding the CSP airbox solution. rich Would be cool if that link should show up! |
Mar 16 2016, 12:25 PM
feel free to use google for an hour and find it...
good things come to those who put in the effort. Rich |
Mark Henry |
Mar 16 2016, 12:37 PM
Elliot Cannon |
Mar 16 2016, 12:55 PM
I love the way my carbs sound. But then again, I drive with these. (IMG:style_emoticons/default/biggrin.gif)
rgolia |
Mar 16 2016, 01:14 PM
JmuRiz |
Mar 16 2016, 05:44 PM
914 Guru Group: Members Posts: 5,424 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
912 air boxes would be the easiest to find (I would think)
Those units from BAS and CSP are great looking! |
wndsrfr |
Mar 16 2016, 07:33 PM
Senior Member Group: Members Posts: 1,428 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
RickS |
Mar 16 2016, 11:00 PM
Senior Member Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
Put two layers of a light weight Dynamat like product behind the back pad to reduce noise but my carbs aren't screamers, it's just induction noise.
7TPorsh |
Mar 17 2016, 09:03 AM
Ideas? Somewhere I saw someone using Honda Goldwing? (maybe) air filters to cut the induction noise....maybe 3 years ago or so...... Bingo! I had this in the back of my head too just couldn't recall through the fog. I just purchased a pair off ebay for less than $30 shipped so this will be the project. http://www.914world.com/bbs2/index.php?showtopic=194570 |
7TPorsh |
Mar 17 2016, 09:15 AM
As I have done some research overnight it seems that the breather boxes from the 1984-1987 Honda Goldwing 1200 are the ones.
My original thought was to have these type of boxes fed by a common cold air tube but I like how this setup is, nice and clean. I think these molded boxes will do more noise reduction than metal ones like the turbo hats. |
rhodyguy |
Mar 17 2016, 10:00 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,070 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
can you provide a link to the picture of the gold wing parts?
7TPorsh |
Mar 17 2016, 02:43 PM
can you provide a link to the picture of the gold wing parts? Here is the ebay search page...you just need 1984-1987 Honda Goldwing 1200 air breather box....probably available outside ebay and at the picker part. http://www.ebay.com/sch/i.html?_odkw=goldw...ox&_sacat=0 |
aircooledtechguy |
Mar 17 2016, 03:32 PM
thedubshop.net made this recently and it really quiets it down. |
veltror |
Mar 18 2016, 01:22 PM
Senior Member Group: Members Posts: 928 Joined: 27-April 08 From: Potters Bar Herts UK Member No.: 8,978 Region Association: None |
moorepower |
Mar 18 2016, 02:58 PM
Member Group: Members Posts: 55 Joined: 9-May 15 From: eastern Nebraska Member No.: 18,718 Region Association: Upper MidWest |
Lo-Fi Version | Time is now: 30th April 2024 - 06:37 PM |
