Quiet Down A Dual Carb Engine..It Works, Honda Goldwing 1200 Air Boxes....Sound Clips |
7TPorsh |
Mar 16 2016, 11:13 AM
7T Porsh Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California |
Finally fixed my exhaust leak so a little more quiet but my carbs scream!
I have seen the expensive airbox for sale around $900 but has anyone found any other solution? I am thinking of using the Turbo Hats and running the input tube bellow the engine tin to a cone filter. Or are there any type of plastic molded airboxes out there that I can graft the weber bottom plate to? Running the open K&N filter housings. Ideas? |
rhodyguy |
Apr 4 2016, 11:59 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,080 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Very quiet now. VERY nice for a full day behind the wheel. The 2 horned ends on the top are for induction yes? How much were the GW filters?
7TPorsh |
Apr 4 2016, 12:27 PM
Very quiet now. VERY nice for a full day behind the wheel. The 2 horned ends on the top are for induction yes? How much were the GW filters? Horns on top are the intakes. I used the K&Ns I had since the Honda paper filters I bought were a little too small and didn't clear the velocity stacks. The K&N seal down tight. The pair of boxes were around $35 delivered....if you don't use velocity stacks the Honda paper filters will work....filters are about $10 each. |
Lo-Fi Version | Time is now: 20th May 2024 - 03:25 PM |
