Go Big or Go Home: Clay's 914-6, MS3Pro Wiring in Progress |
ClayPerrine |
Mar 17 2016, 08:54 PM
Life's been good to me so far..... Group: Admin Posts: 15,368 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
It begins:
Just arrived from Hawaii... 3.6L 964 motor. Destined to become a 4.0L with 993 RS cams. I am keeping the FI so it is a bit more drivable than the MFI motor I have now. I actually started this years ago. I bought a 3.6, but it turned out to be unusable. But I had already bought the LN engineering pistons, cylinders, rods and stud kit to make it a 4.0. So now I get to use all that stuff!. |
whitetwinturbo |
Mar 17 2016, 10:00 PM
Honey, does this wing make my ass look fat? Group: Members Posts: 1,391 Joined: 22-October 11 From: Newport Beach/Kalefornya/USA Member No.: 13,704 Region Association: Southern California |
Andyrew |
Mar 17 2016, 10:11 PM
Build off challenge?
That being said Im looking forward to this engine build (IMG:style_emoticons/default/smile.gif) |
EdwardBlume |
Mar 17 2016, 11:10 PM
4.0 Porsche motor in a 914...... (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif)
0396 |
Mar 18 2016, 04:13 AM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
914forme |
Mar 18 2016, 05:06 AM
stevegm |
Mar 18 2016, 07:26 AM
Advanced Member Group: Members Posts: 2,111 Joined: 14-July 14 From: North Carolina Member No.: 17,633 Region Association: South East States |
Interesting engine build. Are you planning to do the 2017 Build-Off Challenge?
theleschyouknow |
Mar 18 2016, 11:13 AM
Senior Member Group: Members Posts: 523 Joined: 4-June 13 From: Texas Member No.: 15,967 Region Association: None |
sweet glad you found one! let me know if you ever need a hand I'm not much of a wrench but I can follow directions (IMG:style_emoticons/default/beerchug.gif) cjl |
Mueller |
Mar 18 2016, 11:22 AM
Dang...that will be a fun motor!
I figured only pineapples got exported from HI (IMG:style_emoticons/default/smile.gif) |
Mark Henry |
Mar 18 2016, 11:24 AM
porschetub |
Mar 18 2016, 11:38 AM
Advanced Member Group: Members Posts: 4,695 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
It begins: Just arrived from Hawaii... 3.6L 964 motor. Destined to become a 4.0L with 993 RS cams. I am keeping the FI so it is a bit more drivable than the MFI motor I have now. I actually started this years ago. I bought a 3.6, but it turned out to be unusable. But I had already bought the LN engineering pistons, cylinders, rods and stud kit to make it a 4.0. So now I get to use all that stuff!. Great find,had the original car suffered from an interior or engine fire?. What plans do you have for a gearbox,stock or 915 ?,cheers. |
ClayPerrine |
Mar 18 2016, 01:15 PM
naro914 |
Mar 18 2016, 02:49 PM
Losing my mind... Group: Members Posts: 2,476 Joined: 26-May 06 From: Charlotte, NC Member No.: 6,073 Region Association: South East States |
0396 |
Mar 18 2016, 02:57 PM
If you're going to install factory 993RS cams. .you better buy now às I believe there's only one more in stock at the factory.
ClayPerrine |
Mar 18 2016, 09:15 PM
I plan on using a Boxster 6 speed for a transmission. How?? Bubble gum and bailing wire. (IMG:style_emoticons/default/biggrin.gif) Seriously, I have been researching this for a while now. I will document it here for everyone to see. If you're going to install factory 993RS cams. .you better buy now às I believe there's only one more in stock at the factory. I am not using "Real" 993RS cams. I want to leave them for someone who really needs them for a 993RS. I will be getting aftermarket cams with the same grind. |
ClayPerrine |
Mar 18 2016, 09:17 PM
ClayPerrine |
Mar 18 2016, 09:27 PM
A little gratuitous engine porn:
(IMG:http://www.914world.com/bbs2/uploads/post-1143-1229836904.jpg) I started this project years ago, and it got sidetracked by life (layoff from my job) and a bad crankshaft. Original 4.0 Build Thread I am glad it is finally going again. |
Mueller |
Mar 18 2016, 11:09 PM
I plan on using a Boxster 6 speed for a transmission. How?? Bubble gum and bailing wire. (IMG:style_emoticons/default/biggrin.gif) Seriously, I have been researching this for a while now. I will document it here for everyone to see. I'm not giving up on my quest for using a Boxster transmission yet , hopefully you'll figure it out before I get back to mine so it'll be easier for me (IMG:style_emoticons/default/smile.gif) |
ClayPerrine |
Mar 19 2016, 06:48 AM
Interesting engine build. Are you planning to do the 2017 Build-Off Challenge? There is an official contest? I thought it was just for motivation and sharing with the board. I just read the thread. I don't qualify. I am only doing a drivetrain replacement. |
kid914 |
Mar 19 2016, 08:23 AM
ALWAYS lead...NEVER follow!!!! Group: Members Posts: 2,534 Joined: 9-March 11 From: Canada Member No.: 12,811 Region Association: Canada |
4.0 ? (IMG:style_emoticons/default/w00t.gif)
I thought of doing this awhile back. (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/drooley.gif) (IMG:style_emoticons/default/first.gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) |
Lo-Fi Version | Time is now: 29th March 2024 - 06:32 AM |
