Go Big or Go Home: Clay's 914-6, MS3Pro Wiring in Progress |
ClayPerrine |
Mar 17 2016, 08:54 PM
Life's been good to me so far..... Group: Admin Posts: 15,450 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
It begins:
Just arrived from Hawaii... 3.6L 964 motor. Destined to become a 4.0L with 993 RS cams. I am keeping the FI so it is a bit more drivable than the MFI motor I have now. I actually started this years ago. I bought a 3.6, but it turned out to be unusable. But I had already bought the LN engineering pistons, cylinders, rods and stud kit to make it a 4.0. So now I get to use all that stuff!. |
burton73 |
Sep 8 2017, 09:35 PM
burton73 Group: Members Posts: 3,515 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Hi Clay,
Why did you not just use a Boxster shifter and cables for this car? I had some words with Renegade on cable shifter for my V8 to 930 trans and he was going on the reasons to get a Boxster trans and using the factory shifter and cables. He said lots of trans around for $2500. And if it went out they where cheep and there where lots of them. Cable shift Co. has there own set up for $700. I sold my Boxster shifter for $50. So they are not that much and cables are going the right way. Bob B |
ClayPerrine |
Sep 8 2017, 09:43 PM
Hi Clay, Why did you not just use a Boxster shifter and cables for this car? I had some words with Renegade on cable shifter for my V8 to 930 trans and he was going on the reasons to get a Boxster trans and using the factory shifter and cables. He said lots of trans around for $2500. And if it went out they where cheep and there where lots of them. Cable shift Co. has there own set up for $700. I sold my Boxster shifter for $50. So they are not that much and cables are going the right way. Bob B I have a boxster shifter. Three reasons: 1. I wanted a stock appearing shifter. 2. I wanted to keep the hand throttle. 3. I have to remove the cable mount on top of the trans to clear the starter. So I decided to remove the lever for the side to side select and run the cable sideways across the top of the trans. That means the lever in the shifter has to be on the other side to get everything to work correctly. Hard to visualize, I know. But I have not made the cable mount for the trans yet. The boxster shifter is a big clunky box sitting on top of the tunnel. I hate the look. It doesn't match the period feel of the car. |
Lo-Fi Version | Time is now: 12th May 2024 - 01:39 AM |
