Go Big or Go Home: Clay's 914-6, MS3Pro Wiring in Progress |
ClayPerrine |
Mar 17 2016, 08:54 PM
Life's been good to me so far..... Group: Admin Posts: 15,416 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
It begins:
Just arrived from Hawaii... 3.6L 964 motor. Destined to become a 4.0L with 993 RS cams. I am keeping the FI so it is a bit more drivable than the MFI motor I have now. I actually started this years ago. I bought a 3.6, but it turned out to be unusable. But I had already bought the LN engineering pistons, cylinders, rods and stud kit to make it a 4.0. So now I get to use all that stuff!. |
ClayPerrine |
Mar 18 2016, 09:15 PM
I plan on using a Boxster 6 speed for a transmission. How?? Bubble gum and bailing wire. (IMG:style_emoticons/default/biggrin.gif) Seriously, I have been researching this for a while now. I will document it here for everyone to see. If you're going to install factory 993RS cams. .you better buy now às I believe there's only one more in stock at the factory. I am not using "Real" 993RS cams. I want to leave them for someone who really needs them for a 993RS. I will be getting aftermarket cams with the same grind. |
Lo-Fi Version | Time is now: 28th April 2024 - 04:53 AM |
