Go Big or Go Home: Clay's 914-6, MS3Pro Wiring in Progress |
Mark Henry |
Oct 9 2016, 02:20 PM
Is the end of the cam visible in front of the oil cooler ? Shouldn't there be a cap there ? 964/993 motors don't have engine mounted oil coolers The motor originally had a power steering pump drive there. I intend to fabricate an AC compressor mount for the same location. On my engine I'm using 993 cams, I cut that drive off to use a stock cooler. I also modified the cam nose to accept regular 911 cam sprockets. Had to weld them up and grind in a woodruff key slot. No more funky 993 sprockets that take $1+k worth of tools to do the cam timing. |
ClayPerrine |
Oct 9 2016, 07:35 PM
Life's been good to me so far..... Group: Admin Posts: 15,474 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Good ideas! Sounds like this is going to be awesome and terrifying. I'm sure Betty can handle it. (And never, EVER, let me drive it! But you already knew that.) --DD If you are EVER near my car, I am going to carry a big piece of cardboard to hold up to keep you from even LOOKING at it. (IMG:style_emoticons/default/biggrin.gif) |
ClayPerrine |
Oct 9 2016, 07:49 PM
Yep... Good Eye. It is an 87. I bought it from the original owner for $700.00 when his pregnant wife let the timing belt go too long. It was 4 years old at the time. It ate all 16 valves and guides. I put another $700.00 into it in machine work. It ran well over 200K after that. Then the engine blew the head gasket. The motor was the 1.6L DOHC, and parts were no longer available, because it was only made for one year. So I got creative. Now it has an JDM SR20DET from a 1991 Pulsar GTiR . (IMG:http://www.914world.com/bbs2/uploads_offsite/67.media.tumblr.com-1143-1476064163.1.jpg) The Pulsar GTiRis the Nissan answer to the Subaru WRX, and was never sold in the US. It came with a 2.0L turbo 4 that develops over 240HP driving all 4 wheels. In my Pulsar, which is much lighter than the GTiR, it uses a Setra SER limited slip 5 speed to drive the front wheels only. It will smoke the front tires in first and second. It is a real sleeper. Looks dead stock from the outside. The paint is faded and dead, then brakes are WAY too small for the motor, and the AC compressor has a blown seal. It is the alternate driver if we lose the truck or Betty's 914. I know... it is a sickness. But I really don't want a cure. (IMG:style_emoticons/default/driving.gif) BTW.. it is for sale if you know anyone who wants it. |
Ferg |
Oct 10 2016, 02:02 PM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
Here was mine, found 2 years ago. Same deal low miles 74k, but after a bit the trans popped out of 5th. Sold it to the mechanic for what I paid.
Attached image(s) |
Dave_Darling |
Oct 10 2016, 04:53 PM
914 Idiot Group: Members Posts: 14,990 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
If you are EVER near my car, I am going to carry a big piece of cardboard to hold up to keep you from even LOOKING at it. Are you sure you can hold the cardboard up high enough to keep me from looking? (I swear, sometimes it really is too easy!!) The Pulsar sounds cool! SR20DET seems to be a fabulous motor. What happened to the BMW? --DD |
Cracker |
Oct 10 2016, 05:13 PM
Advanced Member Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States |
QUOTE Are you sure you can hold the cardboard up high enough to keep me from looking? --DD (IMG:style_emoticons/default/av-943.gif) |
rhodyguy |
Oct 10 2016, 06:49 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,081 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Those GTiRs are pretty cool. The AWD version must be a hoot to drive. Not all that much money if you can live with the RHD. Poor man's EVO. The 914 of modernish nissans.
ClayPerrine |
Oct 10 2016, 07:23 PM
Are you sure you can hold the cardboard up high enough to keep me from looking? (I swear, sometimes it really is too easy!!) The Pulsar sounds cool! SR20DET seems to be a fabulous motor. What happened to the BMW? --DD I don't have to hold it up high. I will just knock you down to my height. The BMW is in the garage. One day I have to finish the the head gasket replacement on it. After I finish my 914. |
ClayPerrine |
Oct 15 2016, 05:48 PM
Today was "Arts and Crafts" day....
I made this This is a rough template made from posterboard to make left heater boxe for my headers. I will be taking this apart to determine the best way to bend the stainless sheet. The right will be slightly different due to the differences in the headers side to side. The openings for the exhaust tubes will be drilled with 1 34 inch hole saw. The slots in the side will be drilled with the same hole saw, but elongated to let the exhaust pipe out. The small end will have a 2 1/4 inch tube attached to it to mount the heater box. The big end of the tapered side will have a 2 /14 inch tube with a 90 dfegree bend attached to it to feed air into the end of the heater box. The tube will run parallel to the tapered side, and will come as far forward as the front of the heater box. I will use hoses to attach to the blower feed in the front engine tin. The factory 964 blower tubing will be used on top of the motor to provide air. Fabricating the heating stuff is slow going. Lots of false steps in the process. It will work out in the long run though. |
ClayPerrine |
Oct 16 2016, 06:21 PM
Did some work on the left heater box.
Transferring the template. Layout work completed template And the heater box test fit on the header. This is the prototype, and will be scrapped, for two reasons. 1. I made all the holes too small and they had to be opened up with a grinder. They look terrible 2. I was told this was stainless, but it turns out it is just galvanized steel. I will build another one out of the galvanized, taking what I learned on this one and refine the design. Then I will make one out of stainless. |
ClayPerrine |
Sep 5 2017, 06:39 PM
Well... this hasn't been updated for a while. If you are wondering where I have been, lots of extra time at work and 3 different minor surgeries, a case of pink eye, and lately prepping Betty's car for the trip to Okteenerfest have been taking my time.
But here's my latest update. Boxster Transmission adapter is coming along. Here are pictures of the 3-D printed parts. This is the first pass at the relief for the DME sensor. It's too tight in some places, and too much taken away in others. Adjustments to take to the place doing the printing. Here is the whole thing mounted to the transmission. The starter adapter. Transmission has not been relieved completely for the starter. I am using the gear drive 914 starter, and mounting the ring gear on the front of the pressure plate. A standard starter won't clear the backup light switch on the transmission. Inside looking at the starter mount. I don't have a picture of the whole thing mounted to the engine. I have to take it off the stand to do that. I will be bringing the pieces to Okteenerfest so you can see it in person. Also, here is the cable shifter. Built from a Toyota Celica shifter (I don't remember who, but someone on here used one and I just borrowed the idea). I wanted to keep the hand throttle, and not go cutting up the floorboard. I also wanted it to appear somewhat stock, so I welded on a 901 shift arm to the top of the Celica shifter. I used a tail shifter base, and fitted the Celica shift box to the top. I cut a slot for the arm, and after a little rebending of the left-right shift arm, it all fits in the car without cutting anything. I still have to make the mount for the cables. I am bring it to Okteenerfest too if anyone wants to see it. As for the adapter.. I am willing to have multiple sets made if anyone wants to go to a boxster 6 speed in their car. But it would have to be a group buy. And I have not made the mounts to hook the transmission to the 914 chassis at the rear. Stay tuned folks... Things are now back to moving along nicely. Attached image(s) |
Rob-O |
Sep 5 2017, 08:48 PM
Senior Member Group: Members Posts: 1,252 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
Impressive work, Clay. I can't wait to see this thing in person.
Since this was all transmission related, are we to assume that the motor is complete? |
jesse7flying |
Sep 6 2017, 03:15 PM
Member Group: Members Posts: 134 Joined: 9-August 16 From: Burleson,TX Member No.: 20,281 Region Association: None |
I always marvel at the inventiveness of the folks on the forum and you're no exception Clay. Nice work!
Maltese Falcon |
Sep 8 2017, 03:37 PM
Advanced Member Group: Members Posts: 4,660 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
Clear them Paint or Powdercoat the engine tin, unless you want them to return to their natural state. The engine tin is still a work in progress. I have to mod the 914-6 tin to fit the 964 motor. You can see the left rear setup I did. Once I am ready to complete it, it will be bead blasted then powdercoated along with the rest of the tin. I have to mod the power steering belt housing before I can make the tin for the right rear. I have to add the holes for the lower spark plug wires in the side tins, and I still have to figure out how to send air to the heat exchangers. It will probably involve holes in the side tin for air feeds from the fan. Clay , Betty...never got on the topic of your build while we briefly met at Rennsport5 , but you are building something epic here. If you are a fan of brass grommets in your seats; Singer might be jonesing your 914 at the next Rennsport ! (IMG:style_emoticons/default/idea.gif) Marty |
ClayPerrine |
Sep 8 2017, 09:24 PM
Clear them Paint or Powdercoat the engine tin, unless you want them to return to their natural state. The engine tin is still a work in progress. I have to mod the 914-6 tin to fit the 964 motor. You can see the left rear setup I did. Once I am ready to complete it, it will be bead blasted then powdercoated along with the rest of the tin. I have to mod the power steering belt housing before I can make the tin for the right rear. I have to add the holes for the lower spark plug wires in the side tins, and I still have to figure out how to send air to the heat exchangers. It will probably involve holes in the side tin for air feeds from the fan. Clay , Betty...never got on the topic of your build while we briefly met at Rennsport5 , but you are building something epic here. If you are a fan of brass grommets in your seats; Singer might be jonesing your 914 at the next Rennsport ! (IMG:style_emoticons/default/idea.gif) Marty Marty, I gotta build something that can keep up with your car. (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/driving.gif) Singer who? Clay |
burton73 |
Sep 8 2017, 09:35 PM
burton73 Group: Members Posts: 3,526 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Hi Clay,
Why did you not just use a Boxster shifter and cables for this car? I had some words with Renegade on cable shifter for my V8 to 930 trans and he was going on the reasons to get a Boxster trans and using the factory shifter and cables. He said lots of trans around for $2500. And if it went out they where cheep and there where lots of them. Cable shift Co. has there own set up for $700. I sold my Boxster shifter for $50. So they are not that much and cables are going the right way. Bob B |
ClayPerrine |
Sep 8 2017, 09:43 PM
Hi Clay, Why did you not just use a Boxster shifter and cables for this car? I had some words with Renegade on cable shifter for my V8 to 930 trans and he was going on the reasons to get a Boxster trans and using the factory shifter and cables. He said lots of trans around for $2500. And if it went out they where cheep and there where lots of them. Cable shift Co. has there own set up for $700. I sold my Boxster shifter for $50. So they are not that much and cables are going the right way. Bob B I have a boxster shifter. Three reasons: 1. I wanted a stock appearing shifter. 2. I wanted to keep the hand throttle. 3. I have to remove the cable mount on top of the trans to clear the starter. So I decided to remove the lever for the side to side select and run the cable sideways across the top of the trans. That means the lever in the shifter has to be on the other side to get everything to work correctly. Hard to visualize, I know. But I have not made the cable mount for the trans yet. The boxster shifter is a big clunky box sitting on top of the tunnel. I hate the look. It doesn't match the period feel of the car. |
partsguy22 |
Mar 27 2018, 09:07 AM
Enabler of bad ideas Group: Members Posts: 23 Joined: 8-November 17 From: FT Worth, Tx Member No.: 21,587 Region Association: None |
I am enabling Clays bad ideas in the form of making his parts for this bad idea One hardened 4140 964 flywheel spacer ready Attached thumbnail(s) |
mb911 |
Mar 27 2018, 03:54 PM
914 Guru Group: Members Posts: 6,854 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Did this trans ever get completed. I would love a 6 speed for my -6
Luke M |
Mar 27 2018, 05:16 PM
Senior Member Group: Members Posts: 1,373 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
(IMG:style_emoticons/default/popcorn[1].gif) ... Great now I need one of these too.. hurry up Clay give it a test.
Lo-Fi Version | Time is now: 20th May 2024 - 09:39 PM |
