Brake Rotors, After 5 Lug Conversion |
Allan |
Mar 25 2005, 08:00 AM
The PO did a 5 lug conversion on my car. I gues it was the right way to do it, drilled hubs and installed 5 lug rotors with studs. My question(s):
1) Does this mean I have the /6 type rotors?, and 2) What is the minimum allowable thickness when getting them turned? Thanks |
Eric_Shea |
Mar 25 2005, 08:22 AM
PMB Performance Group: Admin Posts: 19,274 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Yes... you should use 914-6 rotors.
Minimum thickness on those solid rotors should be 0.35 in (8.9mm) |
Lo-Fi Version | Time is now: 4th May 2024 - 10:50 PM |
