| cooper951 |
Mar 21 2016, 07:34 AM
Member ![]() ![]() Group: Members Posts: 83 Joined: 30-September 15 From: Central Missouri Member No.: 19,219 Region Association: None |
I've had recurring issues with the hot start problem. I had the starter rebuilt with a new solenoid, and I installed the Bosch hot start relay. So far so good. But is there a way to start the car if it happens to me 50 miles from home besides push start? I tried jumping the battery connection on the solenoid to the starter with the ignition "ON" and I could hear the starter "whrrr" but it never engaged into the flywheel. TIA
cooper951 hot start issue Mar 21 2016, 07:34 AM
zambezi whats the condition of the ignition switch? They ... Mar 21 2016, 09:29 AM
cooper951
whats the condition of the ignition switch? They... Mar 21 2016, 09:35 AM
BeatNavy
[quote name='zambezi' post='2318591' date='Mar 21... Mar 21 2016, 10:42 AM
jvmarino If your starter is good, all you need to do is gra... Mar 21 2016, 10:31 AM
cooper951
If your starter is good, all you need to do is gr... Mar 21 2016, 11:09 AM
cooper951
[quote name='zambezi' post='2318591' date='Mar 2... Mar 21 2016, 11:12 AM
Mark Henry So you put the bosch relay in and you're still... Mar 21 2016, 11:15 AM
cooper951
So you put the bosch relay in and you're stil... Mar 21 2016, 11:25 AM
jimkelly i thought hot start had to due with hot gasoline a... Mar 21 2016, 11:28 AM
BeatNavy
i thought hot start had to due with hot gasoline ... Mar 21 2016, 11:36 AM
ClayPerrine
i thought hot start had to due with hot gasoline ... Mar 21 2016, 11:55 AM
Mark Henry
that aside, i put a bosch relay near my starter,... Mar 21 2016, 12:15 PM
jimkelly good points and info.
i may switch to a ford sole... Mar 21 2016, 12:39 PM
ClayPerrine
i may switch to a ford sol... Mar 21 2016, 02:35 PM
jimkelly got ti, thanks. Mar 21 2016, 03:24 PM
ClayPerrine
got ti, thanks.
That would be correct. Both of ... Mar 21 2016, 07:18 PM
screenguy914 It sounds like you merely energized the starter mo... Mar 21 2016, 06:20 PM
cooper951
got ti, thanks.
Where is this relay board loca... Mar 22 2016, 04:26 AM
jimkelly in the engine bay opposite the battery. its behin... Mar 22 2016, 06:43 AM
cooper951
in the engine bay opposite the battery. its behi... Mar 22 2016, 09:52 AM![]() ![]() |
Lo-Fi Version | Time is now: 12th August 2026 - 03:29 AM |
