Rear sway bar, why wont it go in? |
jgiroux67 |
Mar 25 2005, 08:18 PM
Guitar Shredder Group: Members Posts: 593 Joined: 4-June 04 From: Turlock, CA Member No.: 2,157 |
How do you put the rear sway bar in? I have a factory bar that I need to put back in but I cant seem to get it from one side of the car to the other. Do I need to take off the muffler to put it in or wiggle it thourgh the gap between the muffler and the transmission?
Also, what direction is the bend in the sway supposed to be facing, up or down? |
Mar 25 2005, 08:28 PM
Resident German Group: Admin Posts: 41,644 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
taking off the muffler doesn't take long and will help a lot with the mounting. if your car is lowered, run the bar "upside-down" with the bend going UP. that will prevent the droplink from hitting the underside of the trunk under compression ... (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) Andy |
Aaron Cox |
Mar 25 2005, 08:30 PM
i didnt remove the exhaust to weld in the mounts or put the bar in....
its easy... goes right in the area between the heat shield and the body.... |
jgiroux67 |
Mar 25 2005, 09:02 PM
Andy, that worked perfectly. Took like 2 min to get the muffler off.
Thanks Everyone |
Lo-Fi Version | Time is now: 18th May 2024 - 09:18 PM |
