Pedal Cluster, Feels like pedals rubbing together |
Twonicks001 |
Mar 27 2016, 11:23 AM
Newbie Group: Members Posts: 32 Joined: 14-December 15 From: Texas Member No.: 19,458 Region Association: Southwest Region |
Just a quick guestion for those of you who have been down this road.
When depressing both brake and clutch pedals, it feels like they are rubbing together beneath the floorboard. Is this a bushing problem or a sign from above (or below as the case may be) that a pedal cluster rebuild is in my near future. Thanks for any help. |
Elliot Cannon |
Mar 27 2016, 03:18 PM
Go to bdstone914@aol.com for your pedal cluster needs.
sb914 |
Mar 27 2016, 03:19 PM
Surf Guru Group: Members Posts: 4,303 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California |
Mar 27 2016, 03:52 PM
Are they rubbing the plywood floor board?
tomrev |
Mar 27 2016, 04:31 PM
Member Group: Members Posts: 231 Joined: 25-February 14 From: N. Mich. Member No.: 17,037 Region Association: None |
If pushing on one makes the other move, then the common shaft/bushing situation needs cleaning up, or fresh bushings. Sounds like it's crudded up in there.
Chris914n6 |
Mar 27 2016, 06:23 PM
Jackstands are my life. Group: Members Posts: 3,320 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Factory bushings are plastic and are probably toast by now. The clutch tube runs thru the brake tube, so you have to take it apart to fix it. So... the answer is a rebuild anyways.
Twonicks001 |
Mar 27 2016, 07:44 PM
Twonicks001 |
Mar 27 2016, 07:55 PM
If pushing on one makes the other move, then the common shaft/bushing situation needs cleaning up, or fresh bushings. Sounds like it's crudded up in there. Thanks. Nope ..when one is pushed in, the other one stays in place and does not move. Not very dirty in there when I was just there to tweek the brake light switch. She hasn't been out in the elements since I bought her in '75. |
bdstone914 |
Mar 28 2016, 09:23 AM
dis connect either the clutch and accelerator cables. See if the bindind still occurs. Isolate it to the pedals or not. Sometimes the old bushings swell or the parts rust internally causing swelling and binding. Refresh the whole pedal set if anything is needed. The bushings are all the same age unless some one has refreshed it.
Can build you a replacement without having the first returned. |
Twonicks001 |
Mar 28 2016, 09:35 PM
dis connect either the clutch and accelerator cables. See if the bindind still occurs. Isolate it to the pedals or not. Sometimes the old bushings swell or the parts rust internally causing swelling and binding. Refresh the whole pedal set if anything is needed. The bushings are all the same age unless some one has refreshed it. Can build you a replacement without having the first returned. Thanks.....will do as you say and let you know ....if it a rebuild it'll be on your bench by and by... |
RoadGlue |
Mar 29 2016, 03:29 PM
Sonoma County Gear Head Group: Admin Posts: 2,033 Joined: 8-January 03 From: Santa Rosa, CA Member No.: 108 Region Association: Northern California |
Might have the cables wound around each other in the center tunnel. Easy to do and this is one of the symptoms.
Lo-Fi Version | Time is now: 19th May 2024 - 12:19 PM |
