push rod tubes, are there any oversized ones? |
bernbomb914 |
Mar 26 2005, 01:32 PM
one of the oldest Farts on this board Group: Benefactors Posts: 1,873 Joined: 29-December 02 From: Temecula, CA Member No.: 36 |
I have a 78.4 strock crank and 160 spacers which makes my tubes short.What do you do for this problem? they dont seal very good
Bernie |
type47 |
Mar 26 2005, 04:29 PM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
spacers in back of/on the ends of the tubes?
never heard of longer pushrod tubes |
jwalters |
Mar 26 2005, 05:13 PM
Sooo Close....... Group: Members Posts: 1,677 Joined: 14-May 04 From: Huntsville, AL Member No.: 2,068 Region Association: Europe |
Go get some for a harley davidson big engine--they are expandable and adjustable--use T1 seals on the case side and regular thick o rings on the head side--should work out--just a thought really--you got one wide ass motor huh??
What happened, wrong piston pin height and made it work?? |
Jake Raby |
Mar 26 2005, 07:25 PM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
I sell spacers that cure this issue.. They install under the pushrod tubes and allow .180 shims to be ran easily.. They are dirt cheap and waterjet cut from stainless
I custom make tubes for engines super wide, above .180 and they are not cheap.... with .160 you won't need them though my shims will do fine. BTW The cylinder shims on the 3.0 are .400 on each side and thats even with a custom made longer (.200) Nickie.... |
Lo-Fi Version | Time is now: 20th May 2024 - 10:01 AM |
