where does this go??, pictures |
Schnell944 |
Jun 16 2003, 06:31 PM
Member Group: Members Posts: 121 Joined: 4-January 03 Member No.: 86 |
was working in the engine bay today and ended up poping this line out....I havent had the car for long, and havent gotten my haynes manual yet so I cant for the life of me figure out where it goes...the picture shows the end of it and the resti fo it is in the background....you can see the clear hose plugs into a metal inline thing that connects to other hoses. (IMG:http://members.roadfly.com/schnell944/00_00031.jpg)
Joe Bob |
Jun 16 2003, 07:09 PM
Where does it go to? It looks like a vacuum line, could be for a retard or advance for a dizzy....you running carbs or FI?
Bleyseng |
Jun 16 2003, 07:12 PM
Really hard to tell from that picture. Is the car a 1.7 or 2.0? My guess is a 1.7.
Boy, time to replace the battery tray and some of those rubber/plastic hoses with the real McCoy ones especially the high pressure fuel injection ones before you have a fire, My wild ass guess is the MPS. Geoff |
Schnell944 |
Jun 16 2003, 07:26 PM
its a 1.7 L FI. yaya, i know about the tray already. MPS?
Joe Bob |
Jun 16 2003, 07:32 PM
Any thing missing a hose?
Got a hose diagram? BTW....wasn't gonna say anything about the rusty tray....BTDT.... (IMG:style_emoticons/default/blink.gif) |
Schnell944 |
Jun 16 2003, 07:36 PM
tried to see if anything was missing anything...but obviously i couldnt, and I dont have a a diagram right now. can u guys see the place where i described where it's comign from? it's in the lower left corner. thnx
Bleyseng |
Jun 16 2003, 09:47 PM
Oh ok I see the MPS under the decel valve. I would hook that hose back up to the flux capacitor, Chewie!
Geoff |
ChrisReale |
Jun 16 2003, 09:51 PM
Does it hook up to the anti-flashback thing above the thermometer cable, where it attaches to the cooling flap arm? There should be three hoses on it...??
rhodyguy |
Jun 17 2003, 06:33 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,079 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
have you checked pelican for plumbing diagrams? i bet the pass side heat is a bit weak.
kevin |
Aaron Cox |
Jun 17 2003, 09:26 AM
i think auto atlanta has a "good" diagram to work with (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/lol2.gif)
Curvie Roadlover |
Jun 17 2003, 11:17 AM
Two trunks are better than one! Group: Members Posts: 2,025 Joined: 29-December 02 From: Southeast Michigan Member No.: 42 |
courtesy of Pelican Parts
Schnell944 |
Jun 17 2003, 03:31 PM
what does the MPS look like and what does MPS stand for....I'm gonna go try and figure this out now....just got home from work. thanx for the help so far guys
Lawrence |
Jun 17 2003, 03:38 PM
The MPS is a manifold pressure sensor. It's aluminum, and about the size of a hand grenade.
If you look in your photo, you have a thin clear vacuum line going to the small fitting on it. It's just below/behind the battery. -Rusty |
JeffBowlsby |
Jun 17 2003, 03:39 PM
914 Wiring Harnesses Group: Members Posts: 8,501 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
That metal sleeve looks like it mates with either another hose or a fitting/elbow.
On my 74 2.0 I have a sleeve like that that connects to the PCV elbow on the oil filler tower cap. |
Schnell944 |
Jun 17 2003, 03:43 PM
ahhhh...that is where the unplugged hose is connectee to on one side....so i guess it goes in the air filter housing?? couldnt find a hole for it last night...maybe i was tired...i'll go check.
mightyohm |
Jun 17 2003, 03:48 PM
Looks like the breather hose for the right side head.
Schnell944 |
Jun 17 2003, 04:06 PM
ok, so i took another look. there are 3 hoses connected to the MPS. 2 black ones and the clear one im trying to find a home for. looked on the air filter and can see 2 hoses connected to it....but cant find a place for a third like in the diagram.....I think I am missing something totally obvious here. again, sorry for the dumb questions, but I'm not familiar w the car yet.
Schnell944 |
Jun 17 2003, 04:09 PM
sorry, seems as though I overlooked Bleyseng's post....where is the flux capacitor and roughly what does it look like. thnx 4 your patience (IMG:style_emoticons/default/biggrin.gif)
mightyohm |
Jun 17 2003, 04:10 PM
The MPS only has one hose.
Look down by the head on the right hand side. There should be a hole in the engine tin close to one end of the head (I think the rear) that you can slide that hose back into. You might need a flashlight to look down in there. |
Curvie Roadlover |
Jun 17 2003, 04:28 PM
QUOTE(Lawrence @ Jun 17 2003, 01:38 PM) The MPS is a manifold pressure sensor. It's aluminum, and about the size of a hand grenade. If you look in your photo, you have a thin clear vacuum line going to the small fitting on it. It's just below/behind the battery. -Rusty The item in the photo with the clear hose attached to it is the decel valve. |
Lo-Fi Version | Time is now: 12th May 2024 - 10:04 PM |
