74-1.8L, Bur Helpning and dripping a lot of oil Help |
catsltd |
Apr 2 2016, 07:56 AM
Member Group: Members Posts: 181 Joined: 7-June 15 From: Calgary Alberta Member No.: 18,814 Region Association: None |
My 1.8L motor needs some help.
I am at a loss as to where to start,but thinking the heads are as good as place as any. So been reading everywhere and still have questions. 1, Can I pull the heads while motor in the car???,if I got to pull the motor Im screwed as a rebuild is not an option. 2.What do I do with the heads once I pull them???.Cant ship to USA as exchange rate is brutal. So what can I do,local shop took me to the cleaners last year so feeling a bit lost as to options. 3.I cant find a thread on pulling heads,even in search,suggestions or link would sure help. 4.Car runs good new injectors Mallory dizzy,new plugs,etc but oil dripping and big puffs of blue between shifts is bumming me out. 5. Should I bother with a compression test with so many leaks. Really love my new car,but totally overwhelmed right now. Thanks for any help. Grant. |
ClayPerrine |
Apr 2 2016, 08:02 AM
Life's been good to me so far..... Group: Admin Posts: 15,463 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
My 1.8L motor needs some help. I am at a loss as to where to start,but thinking the heads are as good as place as any. So been reading everywhere and still have questions. 1, Can I pull the heads while motor in the car???,if I got to pull the motor Im screwed as a rebuild is not an option. 2.What do I do with the heads once I pull them???.Cant ship to USA as exchange rate is brutal. So what can I do,local shop took me to the cleaners last year so feeling a bit lost as to options. 3.I cant find a thread on pulling heads,even in search,suggestions or link would sure help. 4.Car runs good new injectors Mallory dizzy,new plugs,etc but oil dripping and big puffs of blue between shifts is bumming me out. 5. Should I bother with a compression test with so many leaks. Really love my new car,but totally overwhelmed right now. Thanks for any help. Grant. Grant, You can't pull the heads while the engine is in the car. But you shouldn't have to. The heads won't leak unless they are badly cracked, so I wouldn't worry about that. Start with replacing the push rod tube seals, the oil cooler seals, and the oil pressure sender. All of these can be done with the engine in the car, and they are all well documented on this site. The bonus to the push rod tube seals is you get a valve adjustment and new valve cover gaskets during the fix. You might also check to see who in your area has a 914 and would be willing to help. There are lots of guys on here that will come over and help wrench on your 914 for some hamburgers and a few beers. |
catsltd |
Apr 2 2016, 08:27 AM
My 1.8L motor needs some help. I am at a loss as to where to start,but thinking the heads are as good as place as any. So been reading everywhere and still have questions. 1, Can I pull the heads while motor in the car???,if I got to pull the motor Im screwed as a rebuild is not an option. 2.What do I do with the heads once I pull them???.Cant ship to USA as exchange rate is brutal. So what can I do,local shop took me to the cleaners last year so feeling a bit lost as to options. 3.I cant find a thread on pulling heads,even in search,suggestions or link would sure help. 4.Car runs good new injectors Mallory dizzy,new plugs,etc but oil dripping and big puffs of blue between shifts is bumming me out. 5. Should I bother with a compression test with so many leaks. Really love my new car,but totally overwhelmed right now. Thanks for any help. Grant. Grant, You can't pull the heads while the engine is in the car. But you shouldn't have to. The heads won't leak unless they are badly cracked, so I wouldn't worry about that. Start with replacing the push rod tube seals, the oil cooler seals, and the oil pressure sender. All of these can be done with the engine in the car, and they are all well documented on this site. The bonus to the push rod tube seals is you get a valve adjustment and new valve cover gaskets during the fix. You might also check to see who in your area has a 914 and would be willing to help. There are lots of guys on here that will come over and help wrench on your 914 for some hamburgers and a few beers. I got the valves adjusted last year at a shop,car didnt ,make it home before oil was drained and oil light came on,so thats why I am going to do as much work as I can myself. Would be great to see some local 914 motors to look at,is there a place to look for local owners???. Thanks. |
ClayPerrine |
Apr 2 2016, 08:41 AM
My 1.8L motor needs some help. I am at a loss as to where to start,but thinking the heads are as good as place as any. So been reading everywhere and still have questions. 1, Can I pull the heads while motor in the car???,if I got to pull the motor Im screwed as a rebuild is not an option. 2.What do I do with the heads once I pull them???.Cant ship to USA as exchange rate is brutal. So what can I do,local shop took me to the cleaners last year so feeling a bit lost as to options. 3.I cant find a thread on pulling heads,even in search,suggestions or link would sure help. 4.Car runs good new injectors Mallory dizzy,new plugs,etc but oil dripping and big puffs of blue between shifts is bumming me out. 5. Should I bother with a compression test with so many leaks. Really love my new car,but totally overwhelmed right now. Thanks for any help. Grant. Grant, You can't pull the heads while the engine is in the car. But you shouldn't have to. The heads won't leak unless they are badly cracked, so I wouldn't worry about that. Start with replacing the push rod tube seals, the oil cooler seals, and the oil pressure sender. All of these can be done with the engine in the car, and they are all well documented on this site. The bonus to the push rod tube seals is you get a valve adjustment and new valve cover gaskets during the fix. You might also check to see who in your area has a 914 and would be willing to help. There are lots of guys on here that will come over and help wrench on your 914 for some hamburgers and a few beers. I got the valves adjusted last year at a shop,car didnt ,make it home before oil was drained and oil light came on,so thats why I am going to do as much work as I can myself. Would be great to see some local 914 motors to look at,is there a place to look for local owners???. Thanks. I couldn't tell you about any local owners in Calgary. But hopefully someone will chime in here. Adjusting the valves won't fix the oil leaks. But you have to remove the rockers to replace the pushrod tube seals, so you get another valve adjustment anyway. Take some pictures for us and we can try to help from here. |
Lo-Fi Version | Time is now: 16th May 2024 - 04:57 AM |
