New engine tragedy, Broken valve stem |
Jetsetsurfshop |
Apr 2 2016, 06:36 PM
Senior Member Group: Members Posts: 814 Joined: 7-April 11 From: Marco Island Florida Member No.: 12,907 Region Association: South East States |
On my first outing with the new engine tragedy struck. While giving it a little bit of RPM the engine made a noise I never heard before and then dropped a cylinder. Limped it home and this is what I found today.
That's the top of the valve you see still with the keeper! Damn. Anyone have any thoughts on what happened here? Everything we did was the same as the last build except we installed a more aggressive camshaft. (IMG:style_emoticons/default/headbang.gif) Attached thumbnail(s) |
Mark Henry |
Apr 2 2016, 06:59 PM
Ouch (IMG:style_emoticons/default/sad.gif)
what valves are those? Used stock? Intake or exhaust? I see late adjusters, you shouldn't do that but that would only mash the valve stem end. engine spec details please. |
Jetsetsurfshop |
Apr 2 2016, 07:05 PM
Ouch (IMG:style_emoticons/default/sad.gif) what valves are those? Used stock? Intake or exhaust? I see late adjusters, you shouldn't do that but that would only mash the valve stem end. engine spec details please. 48mm intake 38mm exhaust They are stainless steel. We used the adjusters that the car had on it when I bought it. It was a mid build. What are you suggesting? 2258cc 44 webers Duel springs Old lift on cam was .465 new lift is .533 |
Mark Henry |
Apr 2 2016, 10:00 PM
Ouch (IMG:style_emoticons/default/sad.gif) what valves are those? Used stock? Intake or exhaust? I see late adjusters, you shouldn't do that but that would only mash the valve stem end. engine spec details please. 48mm intake 38mm exhaust They are stainless steel. We used the adjusters that the car had on it when I bought it. It was a mid build. What are you suggesting? 2258cc 44 webers Duel springs Old lift on cam was .465 new lift is .533 Well Valy nailed it and it could be at least part of the reason for the failure. .533 doesn't sound like a mild cam. Still like to know what was the rest of the engine parts you used, specs and more pics of the damage. For one I want to see the head spring/guide boss area. Guessing at what you have and the damage is just a waste of my time. Asking for help, but only giving out half of the info is one of my pet peeves. |
Lo-Fi Version | Time is now: 17th May 2024 - 04:21 PM |
