Front blower motor, Replacing |
shane |
Apr 2 2016, 09:50 PM
Member Group: Members Posts: 355 Joined: 12-February 13 Member No.: 15,518 Region Association: None |
My blower motor never worked and I took my tank out and painting my trunk. So I took out the blower cleaned the terminals were it gets juice and it ran good, it's kinda of firm to spin but seems ok. Is there a good alternative to a $90 Bosch motor just don't want to have to pull my tank later. What's the chance of the old one lasting? Thanks
Junebug |
Apr 3 2016, 03:41 AM
Newbie Group: Members Posts: 20 Joined: 7-May 15 From: East Bay Area NorCal Member No.: 18,713 Region Association: Northern California |
The motors are strong, you need to look inside if you feel it is hard to rotate. When I tore into mine as a non-running unit, I had power to the fan, but did not go. Years of pine needles and other debris had found their way into the impeller and broken a few housing bits, that in turn wedged themselves perfectly stopping the rotation. after a good cleaning and new brushes motor runs good. Some plastic welding of the housing and then I added the black aluminum window screen over the stock inlet grill under the body vents that I read about here. You might be able to see through the two drain outlets before splitting the housing. My experience 2p
Lo-Fi Version | Time is now: 18th May 2024 - 09:41 AM |
