2 questions?, What are these for? Do I plug them? |
JRust |
Jun 17 2003, 01:12 PM
914 Guru Group: Members Posts: 6,305 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
Ok the saga continues! Turns out my oil leak seems to be coming from the hole next to the carbs. It's on the passenger side & sits on the rear behind the carb. This usually has a hoase on it with the FI. After switching to the carb it was left just plain open. Where do I run the hose & should it be plugged. Also the secon one is next to where you add the oil. What do I do there? Just run the hose where? Thanks guys don't have my haynes in front of me!
DNHunt |
Jun 17 2003, 01:17 PM
Goin out on a limb here, but, I believe it is part of the positive crankcase ventilation system and runs from the valve cover to the flashback valve. Should be one on the driver's side too. Maybe run it to a breather box since I think in the FI system it ends up in the plenum
Dave |
Porsche Rescue |
Jun 17 2003, 01:45 PM
With carbs you need a breather box. Kevin (Rhodyguy) in Washington has a nice picture of one installed. Mail him direct and maybe he can send pic.
VW parts stores have them. Bugpack makes one and it comes in a kit with hoses, $29 I think. You want one with four nipples, 3 in (one from each valve cover and one from breather by oil fill) and one out. There is a filter in the box which should catch oil. The "out" hose can be vented down through the engine tin. |
Aaron Cox |
Jun 17 2003, 01:55 PM
im gonna go buy that bugpack breather in a few days...i le t you know.
Porsche Rescue |
Jun 17 2003, 02:03 PM
Jamie, do a search for "breather". There is a thread called "this close Geoff" with a picture of Kevin's engine. The box is the small aluminum rectangle on the left. Also a thread I started "plumbing question 2" will show up and is all about this topic.
JRust |
Jun 17 2003, 04:18 PM
I will definately be getting a breather box kit. There is a VW chop in Salem I'm sure will have it! Hey here is a pic of the leech!
JRust |
Jun 17 2003, 06:00 PM
ok here is some
JRust |
more
ChrisReale |
Jun 17 2003, 06:25 PM
Nice looking car Jamie! I like the color
Bleyseng |
Jun 17 2003, 07:27 PM
Whats with the two different colored turn signals Jamie?? Glad you finally got it running good.
Geoff |
JRust |
Jun 17 2003, 07:30 PM
I have the other side at home. GOt the euro kit from Craig. Stated switching them out one night. Got one done & had a kid catastraphy. So I had to quite that night. COmpletely forgot about until I was looking at the pics. I thought IDIOT! Yes I am but only 95% of the time. The other 5% is my life not involving my914 (IMG:style_emoticons/default/wacko.gif)
rhodyguy |
Jun 18 2003, 05:51 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,075 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
my box has 3 fittings. one to the fill tower and one each to the tubes on the heads. just dumping the resid through the tin and out makes for a big mess. there is a foam block in the box that traps the fumes. watch the elevation of the tubes, try to avoid ups and downs. let gravity do the work. i've been thinking i may need a pcv valve inbetween the tower and the box too. car's packed leaving for cal in 15 min. back in a week or so. taped firesign theater and pink floyd cd's last night. groovy.
kevin " the names danger, nick danger, third eye" |
JRust |
Jun 18 2003, 02:37 PM
I just called the VW autocraft store in Salem. They have the breather box kit. A whopping $32 bucks. I think I can handle that (IMG:style_emoticons/default/wink.gif) . So I'll go get it tommorow & throw it on! I am loving running around in the Leech again (IMG:style_emoticons/default/biggrin.gif)
Lo-Fi Version | Time is now: 9th May 2024 - 08:21 PM |
