Bead Blasting is awesome!, New Cabinet is up and Running! |
Qarl |
Jun 17 2003, 06:19 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
I finally finished setting up the bead blast cabinet I bought from TP Tools.
I've never blasted before. Boy is it fun and it works great! See below. Attached image(s) |
Qarl |
Jun 17 2003, 06:20 PM
These parts had a lot of surface rust and grime on them.
Now just the bare cast metal! Woo hoo! (IMG:style_emoticons/default/smilie_pokal.gif) Attached image(s) |
yarin |
Jun 17 2003, 10:32 PM
'14-X'in FOOL Group: Members Posts: 988 Joined: 13-May 03 From: Guttenberg, NJ Member No.: 693 Region Association: North East States |
How much was the cabinet with vacuum and lighting?
What type of sand do you use? Silica glass? I used one with and it works REALLY well. I found plans to build one, its not very difficult. No time yet. |
Qarl |
Jun 17 2003, 10:37 PM
Cabinet was $299. Lighting came with it. I just plugged my ShopVac into the ferrule.
I paid $65.00 for an accessory kit (extra gloves, viewing glass protective film, sifter, carbide tip http://www.tptools.com/product.asp?base%5F...0P1TVDB1XTJ27C2 |
914werke |
Jun 17 2003, 10:41 PM
"I got blisters on me fingers" Group: Members Posts: 10,057 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Damn! I have Tool envy! (IMG:style_emoticons/default/pray.gif)
ChrisReale |
Jun 17 2003, 11:17 PM
Ok, Karl, look for my front A-arms, rear trailing arms in next weeks mail (IMG:style_emoticons/default/beer.gif)
Qarl |
Jun 17 2003, 11:25 PM
This really was not an inexpensive proposition...
In addition to the cabinet and accessories, you've got the BFC (big f-ing compressor) too. But that can be used for many things... (like inflating tires)... ha ha! You need a BIG compressor with 60 or 80 gallons and a high flow rate. This one is an 80 gallon at 18 cfm flow. I crank it up, build the pressure and it auto-shuts off when it's pressurized... it kicks on as needed. I was looking for anything rusty this evening to clean it... an old axe head, tools, etc. I blasted the headlight holder/adjuster assembly as well. Was full of surface rust. It's now just plain metal. I will paint with POR-15 gray to keep it rust-less in the future. I plan on blasting lots of parts.. including the pedal cluster, suspension components, some of the hardware, etc. It's also very quick. I did the parts pictured above in about 5-6 minutes. Later! |
Gint |
Jun 18 2003, 09:31 AM
Mike Ginter Group: Admin Posts: 16,071 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Nice cabinet Karl. I've had a very similar setup for the last couple of years. It's really cool to just take your rusty part to the cabinet and have it totally clean in 5 minutes or less.
You want to have some more fun? Get a powder coat gun and clear coat some of that freshly bead blasted steel. It makes an awesome and unique finish. |
airkewl |
Jun 18 2003, 02:24 PM
Newbie Group: Members Posts: 45 Joined: 9-January 03 From: Seattle (Kirkland) Member No.: 120 |
Harbor Freight has a similar unit
http://www.harborfreight.com/cpi/ctaf/Disp...temnumber=39170 on sale now through July 7th for $199 (normally $299), includes the nozzle. I am planning to go get one. Tony |
Qarl |
Jun 18 2003, 02:27 PM
Looks like a nice cabinet for the $$$$.
Make sure your compressor is up to snuff. I can drain the 80 gallon tank in minutes because of the air this thing sucks out. |
Gint |
Jun 18 2003, 02:31 PM
QUOTE Harbor Freight has a similar unit That's the one I have. I did add a whip hose to the gun and mounted it permanently to the front of the cabinet with a coupler on the outside. Initially it comes with a hole in front of the cabinet and a cheasy hose and clamp for the gun. Well worth the extra $10-15 bucks. Other than that, it's a great unit. But as Karl said, you need a lot of air for a blast cabinet. I have an 80 gallon 2-stage compressor also. My pump will build pressure in the tank while I'm using the blaster, but that tank will drain in no time. If you use a 5 hp compressor, single stage or smaller tank unit, you're going to be pushing the duty cycle of your compressor big time. |
goobu |
Jun 18 2003, 03:57 PM
Newbie Group: Members Posts: 26 Joined: 17-June 03 From: New Jersey Member No.: 836 |
Is this like a parts cleaner? I have seen ones that use solvents to clean the parts. This seems more like sandblasting.
What are the pros and cons of each? |
Jeff Bonanno |
Jun 18 2003, 04:08 PM
il dottore Group: Members Posts: 421 Joined: 30-April 03 From: San Diego, CA Member No.: 636 |
your fingers usually survive a little solvent (IMG:style_emoticons/default/wink.gif)
Qarl |
Jun 18 2003, 04:11 PM
You don't use your fingers for the bead blasting... You have heavy gloves you hold the parts with or, place them on a grate in the box.
Bead blasting uses glass, or aluminum oxide, or some other media. Glass produces a nice soft finish that isn't as harsh as sand blasting. Bead blasted surfaces replate and powder coat well. Regards, Karl |
mr914 |
Jun 19 2003, 09:40 AM
914 Hillbilly Group: Members Posts: 576 Joined: 11-January 03 From: Lincoln NE Member No.: 131 Region Association: None |
Blasting is good therapy (IMG:style_emoticons/default/blink.gif)
Jeff Bonanno |
Jun 19 2003, 10:06 AM
kidding Karl, just kidding!
i have the portable blaster - nozzle, feed tube, plastic tub with shoulder strap. i have resisted getting the enclosure because the duty cycle issue Gint mentioned above applies to my compressor. i may build one for the small stuff on this project. Jeff |
Mueller |
Jun 19 2003, 10:11 AM
I bought the 299 Harbor Frieght model a few months back...the idiots didn't drill the thru hole in the gun for it to suck up the media !!!!
Not that big of deal, but still annoying. 7.5hp Rotary Compressor, 60 gallon tank... no problems with airflow (IMG:style_emoticons/default/smile.gif) |
Jeff Bonanno |
Jun 19 2003, 10:16 AM
Karl,
aren't you building a new house? are you outfitting the garage(s) custom to accomodate all these great toys? the movers are going to love you... jbb |
Qarl |
Jun 19 2003, 10:46 AM
Yes Jeff...
Holding parts with your bare hands while blasting would be blood blasting... ha! Yes, I am building a new house. I will have a shop area in the garage to house the compressor and cabinet, plus tools, blah blah. Yes, the movers will love moving that 550 lb compressor around. I left it on the pallet for now until I move to make it a little easier. But still that is really heavy. I am going to install some black and white checkered flooring as well (maybe Racedeck or Kiwi tiles).... anyone have any experience with these products or something similar? Later! |
Jeff Bonanno |
Jun 19 2003, 11:05 AM
Karl,
i saw a longish post on garage flooring material - think it was over at the PP 914 BB - ah yes, here it is: http://forums.pelicanparts.com/showthread....threadid=107108 jbb |
Lo-Fi Version | Time is now: 12th May 2024 - 11:49 PM |
