Need Adavnce Curve Data for 73 2.0 Distributor |
piscean914 |
Apr 14 2016, 09:31 AM
Member Group: Members Posts: 100 Joined: 6-February 04 From: seattle, wa Member No.: 1,637 |
hey guys - i haven't been able to find this info out there - does anyone have the advance curve data for the distributor for the 73 2.0? and for the 76 2.0? if so, then please post here!
thanks in advance! - brad |
PancakePorsche |
Apr 15 2016, 02:24 AM
Member Group: Members Posts: 236 Joined: 29-July 11 From: Southern California Member No.: 13,373 Region Association: None |
I have never seen such document but there was 3 differences in mechanical curve and 2 types of vacuum units if you check the part numbers. I used a 73 distributor combo, 74 injectors and ECU on my GC code 76 and it was a top performer. Still easily passed smog here in CA !
http://members.rennlist.com/pbanders/djetparts.htm#parts |
914Sixer |
Apr 15 2016, 06:52 AM
914 Guru Group: Members Posts: 8,895 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Per White Spec Book:
73 Starts 900-1100 rpm ends 3000 rpm Degrees 8-10@1500 rpm ends 20-24@3000 rpm 76 Starts 950-1050 rpm ends @3000 rpm Degrees 4-9 @1500 ends 22@3000rpm |
Lo-Fi Version | Time is now: 29th May 2024 - 09:46 AM |
